F350-F450 Crew, MPG - Ford Truck Enthusiasts Forums
F350-F450 Crew, MPG
Old 10-23-2011, 08:56 PM
shrek_4 shrek_4 is offline
shrek_4 is starting off with a positive reputation.
F350-F450 Crew, MPG
Hi all !!!
Newbie here... i'm in market to buy my first dually and i was wonder what's the MPG between the F 350, gear 3,73 4x4, crew, 2012 and F 450, gear 4,30 4x4, crew, 2012.
I should sign this week for one of those tow choice, the F350 have to order it and the F 450 is on the dealer lots and have my prefered colord, but i'm afraid the 4.30 gear kills the MPG.
Loaded and unloaded please!!!
Thanks.
Old 10-23-2011, 09:13 PM
Kep4's Avatar
Kep4 Kep4 is offline
Jäger
Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.
Truck in my sig with 3.73's and just over 10,000 miles driven:
Around town I get 15 to 15.5 if I drive like an egg is under the throttle, 13 to 13.5 when I drive with my usual semi-lead foot style.
Highway is 17 to 18 unloaded driving 55 to 60, 16.5 mpg or so at 65+.
Towing I get 10 to 11 with my 12K trailer going 60 to 65.
How often do you tow and how heavy?
Old 10-23-2011, 09:14 PM
952X4's Avatar
952X4 952X4 is offline
952X4 is starting off with a positive reputation.
I get 18-19 running solo and 11.5 to 12 towing my fifth wheeler.. I'm pretty easy on the throttle and tow at about 62... Much better than my 2008 with the 6.4.
Old 10-23-2011, 09:36 PM
I tow aroud 12k, one or two time a week, sometimes more, but that's an averages and every two threes week i tow my camper trailer aroud 12k. I make about 26k miles a years.
Thanks for respond.
Old 10-23-2011, 10:16 PM
Kep4's Avatar
Jäger
There may be a difference in cost of annual registration between the 350 and 450 so check your state motor vehicle dept. for that info, insurance may be a cost difference as well. A 350 DRW will certainly fulfill your towing needs, unless they make you a swingin' deal on that 450.
Old 10-23-2011, 10:19 PM
jim48's Avatar
jim48 jim48 is offline
jim48 has a good reputation on FTE.jim48 has a good reputation on FTE.jim48 has a good reputation on FTE.
I have F350 dually, chassis cab with 4.10 rearend. Tow 5th wheel let me know if you want my info.
Jim
Old 10-23-2011, 10:28 PM
brandon4 brandon4 is online now
brandon4 is gaining momentum as a positive member of FTE.
Jim tell us what you get with 4.10s.
Old 10-24-2011, 12:05 AM
jim48's Avatar
I got back the first week in September Travis AFB, Ca to Kansas, 1792 miles each way. Last truck was F250 FX4. This truck does much better on fuel with the same 5th wheel, same speed and same route.
1. Pulling 5th wheel in wind low of 9.5 (60 mph)
2. Pulling 5th wheel no wind 11.5-12.1 (60 mph)
3. Empty is usually 19 mpg and as high as 20.1 even 21 once in a while (60 mph)
I had 1200 miles on truck when we left for California in May now have 10,000. Pull the 5th wheel almost all the time in 6th, and stays at 1800 rpm. I struggled hard between 3.73 non LS and 4.10 LS. I am very happy with the truck and would not change a thing.
Maybe if I drove faster the lower geared rear end would be worse on mileage. However I don't drive faster than 60 empty or loaded, just an old grandma. I'm never in a hurry. Hope this helps, good luck with your decisions.
Jim
Old 10-24-2011, 12:21 AM
cummins cowboy's Avatar
cummins cowboy cummins cowboy is offline
cummins cowboy is gaining momentum as a positive member of FTE.
the chassis cabs have had some engine problems for some reason, I think the 450 has a different motor??? than the 350's do, someone correct me if I am wrong.
also I would want 3:55's if you can get them. anything more than that is too much gear IMO on these trucks. my truck is 3:31 and I think it will pull anything just fine. I say get the 350.
Old 10-24-2011, 01:27 AM
Kep4's Avatar
Jäger
350 and 450 pickups have the same engine/tune.
Chassis/cab 450/550's have a different tune with reduced HP and TQ ratings and there have been some past issues with those engines.
Old 10-24-2011, 02:30 AM
marine57_4 marine57_4 is offline
marine57_4 is starting off with a positive reputation.
had an 08 f-450 and i almost bought an 11 f-450. after specking both the 350 & 450, the gcvr of my 08 f-450 was 26k and the 11 f-350 is 29k. i went with the 350 for two reasons. the 373 ls gears and the insurance cost. the 450 was rated "commercial" and so the ins cost was more. the only thing i miss from the 450 is the turning radius. pull a 15k fiver at road speeds all the way to 75 mph. fuel is 9-10 average. empty averages 16. same on mph.
Old 10-24-2011, 11:04 AM
Thank guys.
The 350 seem to be not bad at alll, but the 450 is all ready at dealer parking so don't have to wait for delivery, i wonder what those guys whith the 450 is the MPG. i don't whant like 10 and 11 MPG unloead pacing in town and that is what i'm afraid whith the 4.10 gear.Both truck have decent price. Both gone be commercial rated.
Old 10-24-2011, 08:17 PM
Quote:
Originally Posted by shrek_4 View Post
Thank guys.
the 450 has 4:30 gears not 4:10 so fuel milage will differ from the 4:10. first time i have heard that the 350 is rated commercial. the wait won't hurt but it is your choice.
Old 10-24-2011, 09:29 PM
Davgt500's Avatar
Davgt500 Davgt500 is offline
Davgt500 has a good reputation on FTE.Davgt500 has a good reputation on FTE.
My 350 gets an average of 9.3 when at work towing 30k gvw half the day and 20k gvw the other half. When not towing around town I average 14.
Old 10-24-2011, 10:38 PM
deedsF350 deedsF350 is offline
deedsF350 is starting off with a positive reputation.
i got a cab and chassis 4x4 4.10LS
i get around 16 in city
around 15 running 55 to 65
around 13 running 75 to 80
ive seen as low as 12.6 running between 80 and 95 yes i was in the gas hard
but i was ready to get home lol
all these are running empty
Fuel usage F450 towing???? invstr55 2017 Super Duty 21 09-24-2016 11:21 PM
2010 F350 vs 2010 F450 Pheasanthunter66 1999 to 2016 Super Duty 4 07-04-2016 02:23 PM
Anyone want to trade gears? TSmylie 1999 to 2016 Super Duty 10 08-22-2015 08:53 PM
4:30 vs 3:73 and or gear vendor noidnar 1999 to 2016 Super Duty 6 04-02-2010 08:11 PM
F-450 governed 6.4L diesel kyleheinz56 1999 to 2016 Super Duty 15 05-07-2009 09:09 AM
Tags
2005, 2011, 2012, 4x4, commercial, diesel, difference, f350, f350drw, f450, ford, lariat, mpg, towing, truck, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
