Lug Breaking problems?
I have a 1997 F150, Over the last 2 years I have had all 5 lugs shear off and lost the drivers rear wheel...twice. Once while loaded and once while empty. The lug pattern is 5x135 mm with 12mm studs, I noticed that shortly after they went to a 14mm wheel stud. Did they have trouble with the 12mm studs not being strong enough? It is really annoying and dangerous loosing a wheel on the road, luckily i knew something was up and was pulled off to the side of the road going under 20 mph both times. Tow truck driver thinks the lug nuts were over torqued by the shop that put my tires on, you would think they would've known this might happen and design for it. Any thoughts?
By the way, the second time the wheel trashed the bed side and bent the bumper on the way out and the local Ford dealer put those tire on.
-Brad
-Brad
You really have to watch those tire guys. The last time I bought tires they tightened mine so tight that a 250lb/ft impact gun wouldn't back them off. I had to "BOUNCE" on a 2ft breaker bar. I weight 175. Multiply that be 2 and add some for the bouncing and you are way over the 150lb/ft that is the correct torque. They will be wearing snow shoes in hell before I go back to that National company that sells Tires and I think they also sell Batteries.
Interesting, I found a recall about lug nuts loosening but I have had aftermarket wheels and lug nuts since i bought the truck 5 years ago. 1997 FORD F-150 Recalls
Is there a (somewhat) easy way to switch to 14mm studs or would this be a huge/expensive undertaking? Would my wheels fit back on? Would this require major surgery to the wheel flanges/hubs? Has anyone done this before? Would this make the axle any stronger? I use the truck to haul, and around the farm some, I want to make sure this doesn't happen a third time.
thanks
-Brad
thanks
-Brad
i would say there is a 90% chance that your problem is due more to overtorque, than undersize studs. Considering that steel has a strength of 20,000 psi, i dont see how you could overload the truck enough to break the studs. YOu would have to have if REALLY LOADED, and hit REALLY BIG BUMPS. I would guess you would be breaking springs and frame brackets at that point.
Odd, I would think the Ford dealer would know better but...
Anyway, someone suggested hardened wheel studs for running oversized tires, but I can't find any in 12mm X 1.75 thread, only in 1.5 thread. I'd like all the studs to match (threadwise). I would think that the hardened studs would also hold up a lot better to over torquing, right?
thanks
-Brad
thanks
-Brad
texas60guy
04-10-2004 08:09 PM
