When I bought my 56, it came with the factory keys. With the keys was a metal disk with some letters and numbers on it. Also on the disk it says "detach and record". What is it? thanks.
My code prefix is FE. I was told that the door and ignition were two different keys but I'm not really sure. My ignition key will go in the door lock but it doesn't unlock it.
1953/56: BAAA-8122050-A .. Door/Ignition Lock Set w/keys.
In the mid 1980's, FoMoCo vehicles used one type of key for the doors, another for the ignition. These were 10 cut keys and were the only FoMoCo vehicles that I recall that had this set-up.
