You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Finally got out and wanted to test why my speedometer lights don't work.
Tried new bulbs, nothing.
Headlight switch works great, all other lights work.
Found two wires coming out of the switch with female ends on them. I ran my voltage tester through them with the lights off then on. When the headlight switch is on, they push 12 volts.
Where do the dash light wires drop down and connect and what do they connect to these two wires with? It appears to me that the connection point has been removed.
Anyone have a picture or diagram of what this should look like?
Well on my head switch i got a male tab front and center in top, there is 2 tabs in the bottom which I believed those were for the dome light. My dash lights connect to the top tab... Does your dimmer work??
Yes... I can turn on the dome light. I just have no lights.
I have these two wires that come out of the headlight switch not connected to anything. They come from the same spot on the headlight switch. If I run a voltage meter through both I get 12 V if the headlights are on.
I would believe these connect to the instrument panel lights on either side of the speedo but I do not see where those wires come through.
Hmmmmm.... I wish I could help....I did use the stock switch but i ran aftermarket gauges. All my + wires from the lighting were crimped to one female connection to that tab on the switch.
So all the lights work? Headlights,Turn signals,brake lights, Turn signal indicators, oil,water temp,volt,fuel gauge etc etc.....except the lighting of the speedometer? Did you install any aftermarket wiring? Stock wiring?
How are the bulbs sockets? Grounded? Corrosion? Dielectric grease helps....
I just have two wires with power coming out of the headlight switch. They stop two-three inches from the switch with female ends. It's like I am missing the connection at this point to the lights, like there is some junction point here to the wires on the lights.
To check if they are for the dash lights, see if the voltage you get from those two wires to ground changes when you turn the headlight ****. If it stays at 12V, the two lights will stay at full brightness.
Only has 12 V when power is on from pulling headlights. No power without lights. PO had routed front day time type lights to front bumper so I have been wondering if all this got altered. There is a separate switch for those. Gonna stop by Pep Boys and see if there is an after market 12 V I can get to work.
This might help. I looked up the switch in the service manual, and there is terminal near the end of the switch closest to the dash panel labeled I. This is for the instrument lights. Sometimes you have to loosen the headlight switch and drop it below the dash to see this. The other terminals are marked H (headlights) P (parking lights) R (tail lights) D (dome light) A (stop lights) and B (battery). If you get no voltage at the I terminal, the wire coil in the rheostat (the ceramic part that turns when you turn the ****) may be bad.
Correct. I have power at I. Just nothing connected. Wires stop right under dash. Two female ends connect to nothing. Either the wires have been removed or ???? Dome light does work.
Removing the gauge set is pretty easy, about 6 screws. The wire supplying the lights is pretty easy to identify. Check and see if it has power, you may have a grounding issue to solve. I ran a new ground wire to a bright and clean surface on mine. If that doesn't work, run a power wire from your switch to the light circuit, using one of the wires you mention. Unless someone disconnected something, the issue is likely a lack of ground, so as I said, check there first.
Having just been in that area, I remember all the dash light wires were a medium blue color. There was one lead with two tails that were blue. These just plug into tails coming from the snap-in lamp sockets at the back of the panel. Hope this helps.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
The problem is not missing lights or power... The lights are not connected!!! I think the wire has been completely removed. Rather than a weekend science project, just gonna run a new light. I'll post a picture when I come up with it.
I have two female ends that when connected, and the headlights are on, are producing 12 volt power. It IS the dash light from all descriptions above from 3414. IF there was a 6 volt converter and wire... these are gone.
