Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 10-23-2011, 11:58 AM
mbrowne mbrowne is offline
Garage is empty, add now
mbrowne is starting off with a positive reputation.
Thanks for the 57-60
Will move my 58 project to this site.
  #2 (permalink)
Old 10-23-2011, 01:08 PM
twitbeck twitbeck is offline
twitbeck is starting off with a positive reputation.
nice picture/project
I also am new to this forum and also new to old ford trucks. I like your project. I see disc brakes on an old axel. Newer distributor. 3 2's intake? power steering pump. Seems like a lot of old and a lot of new. Tell us more about it.
Terry
  #3 (permalink)
Old 10-23-2011, 01:23 PM
Tomget's Avatar
Tomget Tomget is offline
Tomget is starting off with a positive reputation.
Cool looking build mbrowne. I've got a 58 CustomStyleside. Mine is pretty hot rodded. It was just a big collection of missing/broken/rusty/and otherwise damaged stuff when I bought it--some ten years ago. I'm pretty much finished--if that ever happens and just drive it now and then for fun. Hope it holds together. I'm retired and such can't spend and do what I did when I was younger, but I try to keep the stuff I've built as long a possible before they put me in the "home" haha. I'll be interested in your future plans. I may know a couple helpful things--not much, but I do remember locating a hard to find 4 headlight relay at NAPA that is inexpensive and still available. I had a hard time finding such a beast when I built mine. So don't hesitate to speak up if you can't find something. As a fridge owner you of course know that we don't have the most popular older Ford trucks and there's not so much aftermarket help and support--but some products now and then.
Goodluck
Tom
__________________
Tom
1948 F-1 312Y,oem4spd,Holley 2150,Merc diff
Other projects: 48IH chopped&channeled,58F100 460 C6 4link pro street
  #4 (permalink)
Old 10-23-2011, 03:03 PM
Thanks, Slow build too many projects also doing a 50 ford 8N tractor and a motorcycle or two. I'm a Ford truck man and have seen way too many 48-56 ford builds. This is a 58 SB big window, but will be using a 57 grill. I did a 3" drop axle with a disk kit from CCP. The rest of the chassis will be stock. Will use ford power assist steering. The motor is a 68 FE 390 mild cam Tri Power and coated shorty headers.
  #5 (permalink)
Old 10-23-2011, 07:20 PM
Tomget's Avatar
Ya we've talked before. I know you're a bike guy and all. Didn't recall you were building a tractor too. I thought maybe your truck would be finished by now, and in a car show somewhere. I can see you do really good work.
__________________
Tom
  #6 (permalink)
Old 10-23-2011, 08:24 PM
spurredon's Avatar
spurredon spurredon is online now
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Hey Browne, I really like the attch. point you have for lifting the engine. Really great idea!
The rest of the work looks great as well. My '60 is as original as practical but I appreciate shiny new stuff from time to time.
  #7 (permalink)
Old 10-24-2011, 10:52 PM
windsor8689's Avatar
windsor8689 windsor8689 is offline
windsor8689 is starting off with a positive reputation.
Looks like your running a tublar crossmember for the engine, did you notch the front of frame to avoid axle and member slapping? Oh and what size tire are you running in the front???
__________________
ERIC
  #8 (permalink)
Old 10-25-2011, 11:26 PM
I used a tubular motor mount kit but did not like the way it fit the motor or how low the motor sat in the frame. I moved it up a little and made it clear the axle. The Front tires are P205-75-15 they're to small will change to a
P215-75-15 and P275-60-15 for the rear.
  #9 (permalink)
Old 10-25-2011, 11:36 PM
My engine cross member is hitting my axle, I'm gonna have to cut the hump then rotate to clear the axle and re-weld it.........I didn't realize it until I had all my mounts and front end done.
__________________
ERIC
Tags
57, 5760, 60, build, builds, ford, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
