Gas Gauge Problem
Gas Gauge Problem
08 SuperCrew 4x4 5.4 flex fuel 37k miles...
Seems that the gas gauge is not working like it should. I filled up last month and while driving around a few days later I noticed that the gauge had not moved. Then I got into the truck turned it on and it showed 3/4 full. Once it was at 1/2 full and when I turned on the trunk the next day it showed 3/4 full. By the time I got to work 5 miles away it had gone back down to 1/2 full. I add gas every 3 days or so since I don't trust the gauge any more unless I fill it up. Any ideas?
I did a search on here and someone else had a corrosion problem but I have no idea where to start looking.
Thanks in advance...
i have no experience with the f150 gauge, but every other gas gauge i had that was faulty it was the sending unit that went bad. usually it is in the tank and expensive.
to save $ i would skip the repair and just hit the trip meter after each fillup and filled up every 200 miles to be safe.
Last one I messed with was on a 1990 F150 and it had a float mechanism on the fuel pump itself which was mounted from the topside of the tank, if they still use that style of system I can see where the float would stick or get stuck, which is what it sounds like is going on to me what with it going from 1/2 to 3/4 back to 1/2. I am probably wrong, but that's my 2 cents on the subject. If I ever have to remove the fuel pump on my truck, I guess I'll know for sure.
Well, i went over to Wally World during lunch and found some Techron. I did a search on here for the fuel level sending unit and read about the sulfur problem. It was $6.47 for a 10oz bottle but it had a $2 off coupon. I had to buy 2 since my truck has the 30 gallon tank and I filled up yesterday.
I'll let you all know how its goes...
86stepsideF150
05-20-2008 05:41 AM
