oil pan question 289 to 302???
I have a 67 F100 that had a 289 from a falcon (I believe) I need to swap the oil pan from a truck 302 due to the oil drain location. I have read there are differences between the 2 engines but I am confused. What will I have to change when I change the oil pan? Will the dipstick work? I know I need a rear sump pick up screen. Is there anything else? also I found a 302 motor parting out from a 93 F150. Will that pan and pick up tube work?
Thanks for the help guys, I know this is where to find the answers!
I would NEVER use a junkyard oil pump or pickup. A new one is good insurance towards your engine's longevity. Why install one that may already be worn out? Plus, some folks (like me) tack weld the pickup tube to the oil pump body so it maintains its relative depth and position to the pan. I've heard of some peeps' pick up tube falling out and wiping out their engine. Air is not a good lubricant.
sancochojoe
02-08-2005 11:31 AM
solid dakota
07-19-2004 04:22 PM
pinegreen
11-15-2000 08:17 AM
