1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Brakes pulsing on new brake job
Old 10-23-2011, 07:13 AM
026TB4U's Avatar
026TB4U
026TB4U is offline
I am having issues with my front brakes on my 2005 Expy 4WD. I recently replaced my front pads and rotors with Napa ceramic pads and Napa premium rotors. After a few weeks of use, I started to notice pulsing. I also bled the system.
I have always had pulsing issues on this truck and that is why i bought the premium rotors. I figured they would be less likely to warp.
Some history and observations:
Before the brake job, the left pad had worn out quicker than the right.
The left was at metal to metal.
After the brake job, the left rotor has grooves on it, whereas the right does not.
Any ideas what might be causing the rotor to warp? Bad left caliper dragging? Weak right caliper?
Thanks.
Any way to troubleshoot?
Old 10-23-2011, 09:47 AM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
Did you check your caliper slide pins for easy nonrestricting movement these will hang up and not allow the caliper to have equal pressure on the pads causing vibration and uneven wear
Old 10-23-2011, 08:28 PM
alloro's Avatar
alloro
alloro is offline
Received 4,174 Likes on 2,419 Posts
Then your left caliper is sticking on the slides, has a stiff/sticking piston, or the brake hose is no good.
BTW, why have you not considered the rear brakes as the source of the pulsation?
Old 10-24-2011, 06:09 AM
026TB4U's Avatar
026TB4U
026TB4U is offline
The rear pads and rotors were replaced about 6 months ago and the rotors look good. They do not have any grooves in them.
So I should disassemble the brakes and check the slides? Do you think the rotor is damaged or warped at this point?
Old 10-24-2011, 09:23 AM
alloro's Avatar
alloro
alloro is offline
I would say yes, but you can bring it into a shop and have it resurfaced instead of replacing it. Heat can be very damaging, because of such I would consider replacing the caliper and bleeding the fluid out. Even if you clean the slides and everything seems to work okay, at the point due to the overheating the caliper might not hold up in a panic stop. The seal inside the caliper could blowout.
Old 10-28-2011, 08:35 AM
026TB4U's Avatar
026TB4U
026TB4U is offline
I don't want to resurface so I will replace the rotor. Would I need to replace the pads as well?
Old 10-28-2011, 10:39 AM
jmmranger's Avatar
jmmranger
jmmranger is offline
pulsing pads
I had this happen after tire change. The tire lug nuts were not tight! Check them when not tight it creates a pulsing effect when brakes are applied-
Old 10-28-2011, 05:32 PM
alloro's Avatar
alloro
alloro is offline
Usually yes you would. The heat glazes them making it take longer for them to stop you.
Old 10-30-2011, 08:42 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
pulsing brakes
me too. Have had it happen with loose lug nuts and again when the bearing retaiing nut was too loose.
eigenvector
1983 - 2012 Ranger & B-Series
04-01-2010 11:30 PM
Saber123316
07-15-2008 05:01 AM
CdnFord Eh
03-09-2007 01:33 AM
lukedraper
1978 - 1996 Big Bronco
10-23-2005 11:18 AM
Eastpark
1997 - 2003 F150
06-06-2005 12:01 PM
Quick Reply: Brakes pulsing on new brake job
