FRONT END TROUBLE
rotate the tires and see if it goes away. If it does, suspect a separating tire or bent wheel. Is your truck a long bed or short bed? Check the carrier bearing (if it has one) to be sure it isn't letting the driveshaft move around. How old are the shocks? Worn shocks will allow the springs to oscillate after a bump and allow the tires to bounce.
its a shortbed and im sure it aint the rims/tires cause its done it with the first set of 36s got rid of those and ran 31s and it did it with those once and i had 35 bf goodrich a/ts on it and it did it once also with those and those are three different sets of rims and tires
front end trouble
Replacing worn out or under performing equipment is not masking a problem, it solves or prevents a problem in the first place. Like you, my truck went down the road just fine until one day at about 35 mph I hit a small bump which caused the whole truck to go spastic. I replaced the steering stabilizer with a Rancho unit and that solved that issue. I also discovered that my shock absorbers were worn out and replaced those with Rancho's as well, my personal brand choice. I also had the tire balance rechecked and discovered they were out of balance as well, tires were almost new. The factory single stabilizer setup was designed for stock size wheels and tires and for normal usage. With you running 36" swampers and going offroading you have far exceeded the capability of the single setup and have caused it to just give out due to the increased load of the larger tires. Just as important are good shock absorbers that are designed for this kind of setup and take any lift the truck has into consideration. As for the clunking that you are experiencing when taking off in forward or reverse I agree with the others that it is probably u-joints, a separate issue from the front end, imho. My experience with u-joints has been that when worn out and sloppy loose that they make a constant thumping noise when driving. I cant see that causing the violent shaking that you describe. Don't put the cart before the horse, you need a dual stabilizer setup without question. If you try to fix the wobble without doing this you will wind up chasing your tail. Again, good luck.
front end trouble
front end problem
Ok, now i am stumped. The reason i kept talking about front stabilizers was because the mechanic at the ford dealership that works on my truck told me that 4x4's come with them from the factory, which made sense to me. I assumed that was the case with your truck. Is it possible that they did not do this until later models than your's? I was also assuming that you have the ttb front axle, maybe you have the sas setup, but i don't think it would make a difference either way as far as this goe's. My stepson had a 1978 f150 4x4 rust bucket with an sas front axle and it had a single stabilizer on it, so i just figured it was standard on 4x4's. Interested to find out what problem is. Have you checked u-joints yet?
mine has a ttb setup and it doesnt have the stabilizer and i havent had a chance to check the u joints yet and imma check the tie rod ends and the pivoting bushings to
Butl85
04-16-2011 10:52 AM
SoArkSI
25
05-03-2007 08:41 PM
Kenworth
09-12-2005 10:19 PM
motorhead_83
11-05-2004 05:20 PM
