what might cause rough idle? - Ford Truck Enthusiasts Forums
Old 10-22-2011, 10:22 PM
mikeyc0120's Avatar
mikeyc0120 mikeyc0120 is offline
mikeyc0120 is starting off with a positive reputation.
Just wondering what would cause a rough idle... not super rough where i'm shaking or sputtering but just listening to it, it jumps around just slightly. I know I've had a problem with something for a while since I've been lacking power for some time now, just doesn't wanna move out of its own way. ICP was replaced about a year ago. Thoughts??
On a second note, I'm looking at a new cps. I understand the black cps is better, but on ebay only black ones found are for older rigs, 94-96... are these what I want? Will they work on mine? And whats the deal with the blue ones??
Old 10-23-2011, 12:39 AM
driximus's Avatar
driximus driximus is offline
driximus is gaining momentum as a positive member of FTE.driximus is gaining momentum as a positive member of FTE.
The New CPS will cause an odd Idle. Last time I looked Clay still had a few old ones. I had the old one throwing codes for injectors 8 and 2 or something dont remember it was awhile ago.
Old 10-23-2011, 02:35 AM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
PO had my truck done recall they put grey cps.
1 1/2 years later now I notice rpm would jump about 100-200 when idle. It only doing that during rain It was little rough it like you had 1 weak injector not fire well.
When drive it cut off all times in rain. It go away when there no rain
I got new grey cps from diesel shop but notice it smaller than Ford one which is bigger.
Old 10-23-2011, 03:51 AM
mikeyc0120's Avatar
Yes mine only jumps a few hundred rpm at idle. So did new cps fix it??
Old 10-23-2011, 12:52 PM
Quote:
It fixed but random it had rough idle it would jump a about 100 rpm or less.
Old 10-23-2011, 12:58 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Quote:
I believe Clay and Guzzle are both out.
If you can find one, I think they are worth it, (It's #3 and #8, BTW) but still keep a spare in the glovebox w/ a 10mm wrench. (I do.)
You can also get them from International, just ask for a CPS for an "International T444E" NOT a Powerstroke, lol! I'd only use a Ford or International CPS.
Old 10-23-2011, 01:01 PM
ToMang07's Avatar
Could my truck be breaking CPS's? rlansdon 1994.5 - 1997 7.3L Power Stroke Diesel 31 04-20-2016 08:55 AM
Gray CPS: Cancelling Power of the Stroke? Tugly 1999 - 2003 7.3L Power Stroke Diesel 17 08-16-2014 08:13 PM
Need help with CPS.....Tell me which one I should get... Drenalin 1999 - 2003 7.3L Power Stroke Diesel 10 12-22-2013 10:37 PM
Clutch shudder linked to CPS??....Theory inside Fordbronco69 1999 - 2003 7.3L Power Stroke Diesel 4 07-27-2013 11:48 AM
IH CPS part #. replace your grey or black CPS with this one!! strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 221 06-17-2010 09:30 PM
Tags
1948, 226, 60, 73, cps, excursion, f250, ford, fords, idle, idlewith, idling, internet, location, rough, t444e, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
