2002 f250 7.3 auto suddenly no throttle - Ford Truck Enthusiasts Forums
Old 10-22-2011, 09:11 PM
randymacbc randymacbc is offline
randymacbc is starting off with a positive reputation.
Comming back from hunting today my truck suddenly lost power and stepping on the accelearator had no effect at all. We were on the highway thru the mountains but on a fairly level stretch for a few miles. Managed to pull the truck and toy hauler over and the engine was running fine but stepping on the accelerator had no effect. The check engine light came on every time I stepped on the throttle and went out when I released it. It started fine but no throttle response. Switched around a bunch of relays and checked the fuses and still nothing. Not liking my parking spot i tried to see if it would move down the road at an idle but it would not. Then I thought to try it in 4 wheel low and as the shoulders were soft it wouldn't move forward so tried reverse and went back a foot, forward again and moved a foot and a half. did this several times and all of a sudden the throttle responded, took it out of 4 wheel and it ran fine all the way home.
Any body have any ideas what would have caused this? I was ready to call a tow truck which would have been several hundred dollar bills for where we were and with the trailer
Old 10-22-2011, 09:15 PM
JOHN2001's Avatar
JOHN2001 JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
Ive had the same thing happen to me but I was stopped and started the truck put it in gear and nothing when I stepped on the petal SES light was on. A few seconds later SES light shut off and all was good again happend twice now, Ill be following this
Old 10-22-2011, 09:16 PM
MTalley's Avatar
MTalley MTalley is offline
MTalley has a very good reputation on FTE.MTalley has a very good reputation on FTE.MTalley has a very good reputation on FTE.
Sounds to me like a throttle position sensor issue.
Old 10-22-2011, 10:10 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
Mis read on my part. Mtalley probably is on the right track
Old 10-23-2011, 05:27 PM
Thanks, did a bit of research on throttle position sensors and problems and that seems to make sense. I have the adjustable pedals and it all seems to be a one piece assembly but I have not been able to find a part number or any listings for the adjustable pedal type online. Anybody know who would carry them or do I have to go to the dealer?
Old 03-28-2012, 08:48 PM
02 F250 adjustable throttle pedal assembly fixed.
well I had no problems with this since that time last October until last Sunday it happened again but it stayed dead with no throttle response.
Being at home I decide to pull the pedal assembly and check it out. First off whoever designed this $800 POS should be hung. Why make a one piece assembly that needs to have the whole thing replaced when a 3 dollar switch goes.
Anyway on my 02 it has the single 5 wire plug and with the ohmeter set to 20k scale and then depressing the pedal I was getting a reading of 3.78 to 1.2 between pins 1 and 3, 4.09 between 1 and 2 didn't change and 0.57 to 3.2 between 2 and 3. Pin 1 being the furthest from the firewall. Between pins 4 and 5 which have a Red with green stripe and Red with yellow stripe wires it was an open circuit with no change. These I discovered were to the Idle Validation Switch portion of the circuitry and that was the culprit.
Being it was sunday and the dealership wants about 800 bucks for this pos assembly I had nothing to lose and took a dremel to the plastic welded rivit nut heads on the switch cover. Went round and round each head with a 1/8 straight bit just enough to have it pop when giving a light pry on the under side of the cover.
Inside is a circuit board type flat potentionmeter for the TPS and similar for the IVS contacts. Sprayed the crap out of it with contact cleaner a few times and checked again and got continuity. Cleaned out old silicone gasket and spray cleaned contacts again and applied new silicone bead for gasket. Seated cover and applied a blob of hot melt glue where the old plastic heat welded bolt heads were and working great since.
Again, whoever designed this piece of crap should be shot. Screw that, hung , then shot.
Old 03-28-2012, 10:45 PM
MTalley's Avatar
Wow. Glad you got it fixed back up, though.
Old 09-02-2013, 05:32 PM
emerald isle emerald isle is offline
emerald isle is starting off with a positive reputation.
gages and pedal dead f250 2002
Hello this is my first post. I have a 2002 f250 7.3 I have had this happen 1 other time . Dash went dead gas pedal went to checked fuse 45 it was broken. Well it just happened again so I checked the fuses all were good. Found out on this site about the wire in shifter chafing. Took it apart found broken wire and fixed it. The dash lights and pedal still dead. My question is now what? What else can control all this stuff that obviously got fried . Any help would be greatly appreciated I learned alot on this site already from you guys!!
Old 09-02-2013, 09:19 PM
canoechris's Avatar
canoechris canoechris is offline
canoechris is starting off with a positive reputation.
Had the same thing happen to me back in the spring you may want to check this out.
http://api.viglink.com/api/click?for...13781745211158
Old 09-02-2013, 10:29 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Kudos to canoechris for bringing up Ken's article.
Pop
Old 08-05-2014, 07:27 AM
stevens7.3 stevens7.3 is offline
stevens7.3 is starting off with a positive reputation.
Unhappy same here
My 02 ford excursion quit on the way to work today it started knocking and missing real bad and the same thing happened with the throttle my starter has a bad spot in it every now and then but I doubt that's related unless it is something very electrical. Pleease help we are supposed to leave for the beach today and the excursion needs to pull our camper!!!
Old 08-05-2014, 11:18 AM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Quote:
Where are you located?
Just so we understand, it is running very bad and smoking (what color) and pedal has little effect because of that? That sounds more UVCH/50 cent mod. Search that.
Or is the truck idling ok but pedal makes no difference? That's the throttle position switch problem above.
It would be best if you fill us in on these details and begin a new thread, that way you'll get better help.
Old 12-13-2014, 07:34 PM
themachine1967 themachine1967 is offline
themachine1967 is starting off with a positive reputation.
No gauge or throttle
Could this OD wire cause my second alternator not to charge still no gauge or throttle #45 fuse blew once not now all it does is idle
Old 12-13-2014, 07:47 PM
Quote:
We don't know what truck you have.
S'more info, please.
Pop
Old 07-28-2015, 08:05 PM
bradj51 bradj51 is offline
bradj51 is starting off with a positive reputation.
I have been dealing with this exact issue for a year. Always happens at the worst time. Towing a load over a mountain pass. Ugh. Sometimes motor dying leaving me with no power steering or brakes. Then sometimes 300 miles without a problem. I had the engine light on when I started it today and decided to tear into it. I followed your directions to a tee. Fired back up. No check engine light. Next time I put some miles on it I will continue my report. I hardly drive this rig except when needed. Crossing my fingers. Thanks for the instruction
Whine-Free Hi-pressure PS Hose Install - THEORY F250_ 1999 - 2003 7.3L Power Stroke Diesel 9 06-29-2016 09:33 PM
1970 Ford Step Van Ice Cream Truck pollockb 1967 - 1972 F-100 & Larger F-Series Trucks 8 11-19-2014 01:04 PM
Dropped to idle and no throttle SBFD8 1999 - 2003 7.3L Power Stroke Diesel 16 10-09-2014 05:49 PM
1987 f150 300 I6 EFI automatic c6 stalling,hesitating, and sputtering drpepperinacan 1987 - 1996 F150 & Larger F-Series Trucks 2 01-22-2012 10:14 PM
Mazda b4000 drivetrain problems sqhunter57 Ranger & B-Series 4 12-17-2010 10:53 PM
Tags
02, 2001, 73, 73l, accelerator, adjustable, assembly, check, diesel, engine, f250, light, pedals, position, response, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
