6.0 Low Oil Pressure/Just Rebuilt - Ford Truck Enthusiasts Forums
Old 10-22-2011, 01:38 PM
kev966 kev966 is offline
kev966 is starting off with a positive reputation.
'03 f350, Last year it blew a connecting rod out the side.(110,000mi) Bought a flood recovered 6.0 from a freind of a freind. Completely dismantled it. Had it honed, crank polished, all new bearings, head studs, egr deleted, black onyx head gaskets. When I fired it up, it had very low engine oil pressure and also a leak in the hpop system. Had enough fun so I dropped it at the dealer to fix. 1 month and $4000 later still not fixed. Brought it home and it sat for a year, then last week I tried to tackle it again. Took the motor back out , brought crank to machine shop to double check the measurements. They polished again and ordered new bearings again. Installed crank,new gyro pump and cover. Put in new stack tubes for hpop issue. I solved the high pressure oil issue, but I still have very low engine oil pressure. 2-4psi at idle and 15psi at 1500rpm. Anyone have any ideas as to what I'm missing here?????
Old 10-22-2011, 01:48 PM
NewToDiesels's Avatar
NewToDiesels NewToDiesels is offline
NewToDiesels is gaining momentum as a positive member of FTE.
How are you measuring?
Old 10-22-2011, 02:00 PM
Oil Pressure gauge, I just looked in the tech guide, it says possibly the oil pressure regulator, any idea where that is ?
Old 10-22-2011, 03:44 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
here ya go hope you get it going sounds like its been quite the ordeal
what kinda oil filter is in it motocraft I hope
And WELCOME to FTE
Old 10-23-2011, 09:43 PM
Thanks BLADE 35
Old 10-23-2011, 09:49 PM
Sorry BLADE35, forgot to answer your question. A Fram oil filter has been put into the 6.0. Is using a Motocraft something I should do versus the aftermarket brands ?
Old 10-23-2011, 10:05 PM
BLADE35's Avatar
Quote:
some AM filters are to short and they use a diffrent cap to make up for the Height diffrence
IIRC Fram ok
stay with motocraft and no worries and that goes for ALL Filters fuel oil air ect....
theres a oil drain back in the bottom of the oil filter housing that drains when filter is pulled get to short of filter in and it constantly is draining make shure nothing wrong with the drainback
Pull and check IPR if it got junk in it and is stuck open will not allow to build aANY pressure
look at the screen if pushed from being plugged or any hole in it time for a new on
Old 10-23-2011, 11:34 PM
Thanks again BLADE35
Old 10-24-2011, 05:22 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
The Fram is fine. If you compare the Fram and Motorcraft I think you'll find that they're dimensionally identical.
Old 10-24-2011, 05:10 PM
Well, I tried the oil pressure regulator today with no luck. I was really hoping that was the culprit. Blade35, does the IPR affect the engine oil pressure? or the High Pressure Oil System?
Old 10-24-2011, 05:31 PM
The IPR (Injector Pressure Regulator) regulates the HPO system. Where are you taking your low pressure reading from?
Old 10-24-2011, 08:27 PM
BLADE35's Avatar
sometimes a bad IPR will cause loss base oil pressure
look at the screen if pushed from being plugged or any hole in it time for a new on <!-- / message --><!-- sig -->
With all the work that went into this truck it wouldnt surprise me if the screen and such was jacked up
__________________
Old 10-24-2011, 11:59 PM
OK I will try the IPR tomorow(tue.) will post the results. One more thing I did find is that I pulled the oil filter, checked both check valves. They were good. Then cranked the motor to fill the filter cup just to double check the valves opening and closing which was good. BUT, I noticed that the oil was airated. Would I be correct to assume that's an issue that would affect oil pressure
Old 10-25-2011, 12:03 AM
p.s. I'm taking the pressure reading from the sending unit port
Old 10-25-2011, 12:19 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Aerated oil sounds like the pump is sucking air. Might be time to check the pickup tube o-rings.
2004 early 6.0 no start dothedew192 6.0L Power Stroke Diesel 10 02-21-2016 10:58 AM
Oil Pressure issues--4.0 SOHC rebuild IronHorseDriver Ranger & B-Series 4 10-02-2015 01:01 AM
6.0 Loss of low oil pump pressure when at operating temp. bpete 6.0L Power Stroke Diesel 1 07-16-2014 07:28 PM
6.0L No Start Mystery dpassarella 6.0L Power Stroke Diesel 17 03-30-2014 08:55 PM
HPOP and oil problems!! No start/run blue66tang95f150 1994.5 - 1997 7.3L Power Stroke Diesel 28 12-19-2012 10:36 AM
Tags
2005, 350, 351w, 360, 60, 60l, block, ford, fresh, la, low, oil, pressure, rebuild, small
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
