axle ratio question
Old 10-20-2011, 10:21 PM
pkorrupted's Avatar
pkorrupted
pkorrupted is offline
axle ratio question
I have a 1959 F250 292 V8 4speed 2wd truck. I am trying to figure out my axle ratio. It is a full floating Dana 60. There is no axle tag on the pumpkin but it does say 60 on the side of the pumpkin. The VIN tag says 04 for the axle. I have searched all over and cannot find this ratio.
Old 10-20-2011, 10:45 PM
pkorrupted's Avatar
pkorrupted
Old 10-20-2011, 10:57 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
PK, I think there were only two gear ratios available for the Dana 60 rear-ends in our 1959 F250.One was 4.56:1, which is what had,and also (I believe) 4.11:1.Not positive on the second one.
I had the gears changed to a more friendly 3.54:1, if I lived in a flat area,would have even went to a 3.23 for better fuel mileage.
Note: I saw where you listed your axle code,04,that means you've also got the 4.56.
Steve
Old 10-20-2011, 11:03 PM
pkorrupted's Avatar
pkorrupted
That's what I was thinking for ratio but I was hoping it was 4:11 not 4:56. 1st gear is absolutely useless and 60 mph is almost on the rev limiter. I am gona definitely get 3:54 gears. That is the lowest ratio I can find of any brand. Are you sure 04 means 4:56 or is that just and educated guess? Thanks
Old 10-20-2011, 11:06 PM
ibuzzard's Avatar
ibuzzard
That is according to the chart in the 1959 Truck Parts and Accessories Catalog that I have.
Old 10-20-2011, 11:11 PM
pkorrupted's Avatar
pkorrupted
Thank you very much. I need to get one of those parts catalog.
Old 10-22-2011, 11:34 AM
pkorrupted's Avatar
pkorrupted
So, since I have 4:56 gears does that mean if I went with 3:54 gears I would have to get a 4:11 and lower carrier? Will 3:54 gears fit on my 4:56 differential?
pkorrupted's Avatar
pkorrupted
Old 10-22-2011, 11:43 AM
ibuzzard's Avatar
ibuzzard
PK,I took my truck to a reputable truck/4-wheel drive shop that did the work quickly,efficiently for about 350.00 ,about 4-5 years ago.They had the correct gearset in stock,they do lots of these change-overs.If you're in a smaller town,though,any good shop can order the parts.I'm in Cali,so what might seem an outrageous price to you guys in other parts of the country,to me is a bargain.Possibly less expensive in other areas.
Steve
Old 10-22-2011, 11:49 AM
pkorrupted's Avatar
pkorrupted
But im still wondering if there are two different differentials for the 4:56-up gears and 4:11-down gears. Will the 3:54 gears work on my 4:56-up differential or do I need to get a 4:11-down diff?
Old 10-22-2011, 11:56 AM
ibuzzard's Avatar
ibuzzard
The exact same Dana 60 housing for the F250(3/4 ton),and will accept different gearsets.AFAIK,it was the only available differential from Ford for an 2WD F250 in 1957-60.Of course, who knows what some deranged previous owner may have thrown in there,then all bets are off.Run it by a good shop,they'll quickly I.D. it for you if you're not sure.
Old 10-22-2011, 03:27 PM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
the 2 ratios used on F250 2WD trucks are 4.56 and 4.88...
- cs65
Old 10-22-2011, 03:56 PM
ibuzzard's Avatar
ibuzzard
- cs65
Thanks for correcting me,Don
Steve
Old 10-22-2011, 04:27 PM
pkorrupted's Avatar
pkorrupted
Thanks guys. I just wanted to make sure if I order 3:54 gears they will work on my diff.
Old 10-22-2011, 08:13 PM
mr4speedford's Avatar
mr4speedford
mr4speedford is offline
You might want call one of the bigger axle part companies and ask, I know the dana 44's in the early trucks used two carriers depending on ratio. I'm willing to bet the 60 is the same way.
toomanycars51
08-25-2011 02:15 PM
classyfish
08-08-2007 04:16 PM
69BigblockFord
05-28-2007 11:06 AM
Featherman
22
05-02-2007 07:44 AM
mmford24
09-16-2004 01:14 AM
Quick Reply: axle ratio question
