Idle up and down - Ford Truck Enthusiasts Forums
Idle up and down
Old 10-21-2011, 11:26 PM
lilman320's Avatar
lilman320 lilman320 is offline
lilman320 is starting off with a positive reputation.
Idle up and down
I have a 99 F-150 4x4 with the 5.4... While idling it will stay around the 800 rpm range for awhile then what sounds like a switch clicks and it goes up to 1100 rpm then repeats thee cycle... It does this cycle constantly, hot or cold, and I'm just curious as to what makes it do this?
Thanks,
Willie
Old 10-22-2011, 12:17 AM
kbsupercrew's Avatar
kbsupercrew kbsupercrew is offline
kbsupercrew is starting off with a positive reputation.
Do you hear this click with the ac on? if so its the ac clutch engaging and disengaging the pcm will increase rpm to handle load, if it is cycling too much 6-8 times a minute indicates low refrigerant pressure levels, get charged or low pressure switch malfunctioning IMO
Old 10-22-2011, 10:08 AM
lilman320's Avatar
That's exactly what it sounds like, but the ac is off...
Old 10-22-2011, 11:35 AM
Ac cycling switch? its on top of the dryer, passenger firewall behind engine harness connector brackets
Old 10-24-2011, 01:19 AM
lilman320's Avatar
Would that be the AC clutch switch? More Information for MOTORCRAFT YH1462 I haven't had a chance to look for the one you described I'll try and get to that tomorrow... Thanks again!
Old 10-24-2011, 09:29 PM
lilman320's Avatar
And also, if I disconnect the switch will I see a difference in the idle at all?
Old 10-24-2011, 10:49 PM
IF you disconnect the connector at the pump or the dryer it shouldnt engage, no a/c, i would think, i never tried
AC clutch not disengaging or cycling. annaleigh Cooling, Heating, Ventilation & A/C 20 07-19-2016 11:19 AM
Loping Idle Until Dying AFTER warmup - 1992 F150 4.9 (300) dananarama 1987 - 1996 F150 & Larger F-Series Trucks 36 10-08-2015 02:48 PM
0171 and 0174 DTC's TexMike3594 1997-2006 Expedition & Navigator 6 07-26-2015 12:37 AM
Ipr duty cycle problem part two Farmboypowerstroke 1999 - 2003 7.3L Power Stroke Diesel 7 12-21-2013 11:40 AM
What cause build up carbon on injector nozzle? Milwaukee1979F150 1999 - 2003 7.3L Power Stroke Diesel 3 08-20-2011 05:45 PM
Tags
1983, 1994, 2003, 289, 60, 69l, cold, explorer, f150, ford, idle, idles, makes, mountaineer, revs, switch, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
