How much does a 360 w/ C4 attached weigh? - Ford Truck Enthusiasts Forums
Old 04-10-2003, 02:23 AM
ADSf100 ADSf100 is offline
ADSf100 is starting off with a positive reputation.
Question How much does a 360 w/ C4 attached weigh?
Wanting to pull my 360 with automatic attached. Thinking about buying one of the cheap'o import cherry-pickers and engine stands on e-bay. Cherry picker is rated for 2 tons and engine stand for 1,000 pounds. Has anyone used these for FE engines?
Old 04-10-2003, 06:34 AM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
The FE weighs about 750 lbs with all the accessories. The C6 weighs qite a bit but I'm not sure. Nowhere near 2,000lbs all together though so you should be fine. Unless you have a special aftermarket bellhousing you have a C6 not a C4. I know the books sometimes say different but that is wrong. The engine stand should also hold. Just be careful and let the weight down slowly.
Old 04-10-2003, 10:07 AM
gtex's Avatar
gtex gtex is offline
gtex is gaining momentum as a positive member of FTE.
Just an FYI. A 2 Ton Cherry Picker, is only rated for 1/2 ton with the boom extended. And you may need to be extended, depending on how you pull it.
I'm thinking the C6 is only about 200 lbs. I rememeber sliding it around and moving it without too much trouble to get it rebuilt.
Old 04-11-2003, 12:35 AM
WoodN1_76 WoodN1_76 is offline
WoodN1_76 is starting off with a positive reputation.
Angry How much does a 360 w/ C4 attached weigh?
I bought a cheepy 750lbs.rated engine stand for my FE motor.
It does the job, but barely and I don't trust it. I didn't realize the 360 was so heavy. I am used to (this is probably a dirty word in this forum)small block chevys and this ford weights a lot more.
Old 04-11-2003, 12:50 AM
Hey Rat, How is a C6 visually diffrent from a C4? Mine has the bell housing as part of the trans bolting directly to the engine (no separate bell housing). Can you or anyone please help me out with some of the other codes. 131 X F103 8 4 G 08
Thanks,
Dale
Old 04-11-2003, 01:58 AM
Chas1234 Chas1234 is offline
Chas1234 is starting off with a positive reputation.
IF the bell is cast as one with the tranny's case then it is a C6 , the C4's bell can be removed
Old 04-11-2003, 05:17 PM
gtex's Avatar
I don't think you're looking at a C4. They never came behind FE engines.
If it is a C4, somebody did some aftermarket mods/adapters to get there.
I've got a 1000lb engine stand , and I was still nervous with my 390 on there. FEs are pretty heavy.
Old 04-11-2003, 07:17 PM
FE427TP FE427TP is offline
FE427TP is starting off with a positive reputation.
FE's aren't THAT heavy, especially after you get the intake off they are barely more than a 351 Windsor. I believe you may also have a FMX behind your engine as another possibility
Engine lifting points? gearhead351 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 09-05-2007 08:05 AM
Using cherry picker on lifted 92 F-150 Jrock909 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 04-05-2007 10:48 AM
How to lift cab or box with cherry picker? marty68 1961 - 1966 F-100 & Larger F-Series Trucks 12 05-24-2006 02:02 PM
Where to attach the cherry picker? Hellbore FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 15 05-16-2006 12:07 PM
HELP: tia removal of a 4.9L engine 86 E-350 van blueknight44 1968-2013 Full Size Vans 7 03-07-2006 01:23 PM
Tags
360, 390, block, c4, c4mineyahoocom, c6, cherry, engine, ford, picker, ton, transmission, truck, weigh, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
