Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
  #1 (permalink)
Old 10-21-2011, 06:57 PM
Tinker bell Tinker bell is offline
Garage is empty, add now
Tinker bell is starting off with a positive reputation.
Ford explorer turn signal lever not working
Purchased new one from Advanced Auto parts. It worked for a few days and is back to doing what the other part was doing. When I engage the lever to turn right it works but when try to signal to the left it doesn't always work. It makes a noise that sounds like it is shorting out and doesn't turn the signal light on. Depending on how I have the steering wheel turned, sometimes I can hold it to allow for the signal to blink. I replaced the lever, that BTW, also operates the brights and the windshield wipers, for the very same malfunction.
I was not able to pass TX state inspection. Now I,m wondering if it isn't something else that may be causing the lever not to engage. can it be a loose wiring harness?
  #2 (permalink)
Old 10-21-2011, 11:20 PM
LV Dan LV Dan is offline
LV Dan is starting off with a positive reputation.
Sounds to me like the new one broke, too. I have replaced my twice already. I opened the switch up to find plastic pieces and contacts all a mess.
__________________
1999 F-350 SD 4x2 dually, 7.3l DI Turbo Diesel, 4R100 Auto, 4.88 LS, std. cab, 165" WB .
1999 Explorer XLT 4x4, 4.0 SOHC, 5R55E, 3.73 LS.
Former Fords: '75 Ranchero, '82 F-250.
  #3 (permalink)
Old 10-22-2011, 08:02 AM
shorod's Avatar
shorod shorod is offline
2010 Lincoln MKT
My Garage
shorod has a good reputation on FTE.shorod has a good reputation on FTE.
Did you actually replace the lever, or the multi-function switch? The multi-function switch is where the electrical contacts are made when the lever is moved for turn signals, high beam headlights, flash to pass, as well as the hazard lights. The MFS is probably the issue.
Also, what year is your Explorer?
-Rod
  #4 (permalink)
Old 10-27-2011, 06:21 PM
I replaced the multi function switch w/the lever. All one piece. It is a 98explorer.
  #5 (permalink)
Old 10-27-2011, 10:37 PM
shorod's Avatar
2010 Lincoln MKT
My Garage
Check the wiring harness that connects to the MFS. Several have been known to have loose contacts or broken wires at the connectors.
-Rod
  #6 (permalink)
Old 10-28-2011, 07:15 AM
Work in progress
Ok, I will check it out. Thanks!... I will let you know. Once I get this resolved, I really want to replace the switch on the driver side that locks and unlocks all the doors....
  #7 (permalink)
Old 10-28-2011, 09:40 PM
shorod's Avatar
2010 Lincoln MKT
My Garage
You might want to read up about that switch a bit too. I've read of a lot of folks that have replaced the switch, but I don't recall anyone following up that a new switch actually fixed the issue. Often it's a broken wire or a bad solenoid.
-Rod
  #8 (permalink)
Old 10-29-2011, 03:03 AM
swshawaii swshawaii is offline
swshawaii is starting off with a positive reputation.
Not sure if this applies to your '98 Ex. Common issue on the Gen1 Sport Trac's.
The steering column binds the wiring when tilted, causing breaks and shorting. GL
http://www.mysporttrac.com/MySportTr...epair_Gen1.pdf
  #9 (permalink)
Old 11-02-2011, 12:59 PM
tomo805 tomo805 is offline
tomo805 is starting off with a positive reputation.
Could this switch also cause the wipers to act erratic? Mine is a 99 explorer and wipers are all screwed up, and turn signal sometimes affects them.
  #10 (permalink)
Old 11-03-2011, 06:35 AM
shorod's Avatar
2010 Lincoln MKT
My Garage
Yes, the multifunction switch (MFS) also has the controls for the windshield wipers and four way flashers/hazard lights. Likewise, the wiring issues mentioned above for the MFS would also be suspect.
-Rod
  #11 (permalink)
Old 11-03-2011, 10:25 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a good reputation on FTE.KhanTyranitar has a good reputation on FTE.KhanTyranitar has a good reputation on FTE.
The one from advance is likely a low quality part. I would get a genuine Motorcraft unit. You old one lasted a long time, can't go wrong with the same thing.
  #12 (permalink)
Old 11-03-2011, 12:09 PM
How much of a job is it to change this part?
Tags
03, 2006, 95, 96, blinker, clicking, directional, explorer, ford, leaver, lever, light, signal, turn, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
