Converting from king pin to ball joint worth the time?
Old 10-21-2011, 06:23 PM
crestfallinman's Avatar
crestfallinman
crestfallinman is offline
Alright I'm playing with the idea of converting my front end To the ball joint style, to those of you who have done this how long did it take you and was it expensive to do?
I have limited expierence woth this kinda stuff and sadly not even a garage hence why I'm debating
Old 10-21-2011, 07:34 PM
Stangrcr1's Avatar
Stangrcr1
Stangrcr1 is offline
I am close to doing this too.
It looks like all we would need is the beams, knuckles, and the brake calipers. The rest should swap.
May go to the JY Sunday and will take a look.
Old 10-21-2011, 08:23 PM
crestfallinman
Alright if you do definitely let me know I'm curious about how involved it will become
Old 10-21-2011, 10:53 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Do you have some sort of issue with the king pin setup? If you're just doing it for the heck of it, it's a step down, in my opinion. Yes, the ball joint setup gives you easier alignment options, but it's nowhere near as durable as the king pins. Properly greased king pins can last well over a million miles.......
Needed parts would be the complete I-beams, radius arms, and spindles. If the spindles are newer than 85, you'll need matching calipers. Rotors, on the other hand, are the same from 73-96, aside from the 4.5" bolt pattern rotors for the F100.
While you're at it, might as well change the pivot bushings. They are very different between years. Radius arm bushings are pretty much all the same, and also should be changed.
Old 10-22-2011, 09:14 AM
crestfallinman
the only reason i want to is because i want to put 1.5 inch drop springs on my truck in the spring and the camber issue will be absolutely horrible so thats why im entertaining the idea, otherwise i would never change from kingpins
Old 10-22-2011, 09:34 AM
Rogue_Wulff
Now that's a reason that makes sense. Raising/lowering with king pins is a royal in the *backside*.
Old 10-22-2011, 10:39 AM
crestfallinman
yeah before i get into it im going to call the local tire shop (best alignments around) and see if they will even consider messing around with that
6.9 diesel nut
07-29-2013 10:15 PM
Macs1964F100
02-21-2013 11:42 AM
TheKirbyMan
16
07-24-2012 11:05 PM
gman30
05-30-2012 02:03 PM
glilly
1999 to 2016 Super Duty
07-21-2009 08:51 AM
Quick Reply: Converting from king pin to ball joint worth the time?
