Converting from king pin to ball joint worth the time? - Ford Truck Enthusiasts Forums
Old 10-21-2011, 06:23 PM
crestfallinman's Avatar
crestfallinman crestfallinman is offline
crestfallinman is gaining momentum as a positive member of FTE.
Alright I'm playing with the idea of converting my front end To the ball joint style, to those of you who have done this how long did it take you and was it expensive to do?
I have limited expierence woth this kinda stuff and sadly not even a garage hence why I'm debating
Old 10-21-2011, 07:34 PM
Stangrcr1's Avatar
Stangrcr1 Stangrcr1 is offline
Stangrcr1 has a good reputation on FTE.Stangrcr1 has a good reputation on FTE.
I am close to doing this too.
It looks like all we would need is the beams, knuckles, and the brake calipers. The rest should swap.
May go to the JY Sunday and will take a look.
Old 10-21-2011, 08:23 PM
Alright if you do definitely let me know I'm curious about how involved it will become
Old 10-21-2011, 10:53 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Do you have some sort of issue with the king pin setup? If you're just doing it for the heck of it, it's a step down, in my opinion. Yes, the ball joint setup gives you easier alignment options, but it's nowhere near as durable as the king pins. Properly greased king pins can last well over a million miles.......
Needed parts would be the complete I-beams, radius arms, and spindles. If the spindles are newer than 85, you'll need matching calipers. Rotors, on the other hand, are the same from 73-96, aside from the 4.5" bolt pattern rotors for the F100.
While you're at it, might as well change the pivot bushings. They are very different between years. Radius arm bushings are pretty much all the same, and also should be changed.
Old 10-22-2011, 09:14 AM
the only reason i want to is because i want to put 1.5 inch drop springs on my truck in the spring and the camber issue will be absolutely horrible so thats why im entertaining the idea, otherwise i would never change from kingpins
Old 10-22-2011, 09:34 AM
Now that's a reason that makes sense. Raising/lowering with king pins is a royal in the *backside*.
Old 10-22-2011, 10:39 AM
yeah before i get into it im going to call the local tire shop (best alignments around) and see if they will even consider messing around with that
Stiff steering knuckle with new ball joints WHEELZCRAZY57 Excursion - King of SUVs 5 01-01-2015 05:21 PM
OPINION?? Best ball joints for the price and where did you get them?? tssngs75 1999 to 2016 Super Duty 5 11-18-2014 04:24 PM
Shock Recommendations? rpenterics 1999 - 2003 7.3L Power Stroke Diesel 12 09-09-2014 10:50 PM
Ball Joint Opinion 69 stang 1994.5 - 1997 7.3L Power Stroke Diesel 3 12-20-2008 08:16 AM
? on ball joint change oldstylefseries 1997 - 2003 F150 2 09-26-2006 09:38 AM
Tags
2wd, 86, alignment, ball, bushings, chang, converting, doesa72fordf100haveakingpinorballjoints, f150, ford, joint, joints, king, kingpin, pin, swap, workhorse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
