Old 11-11-2014, 07:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Excursion Lift Kits / Which One?
  #31
Old 08-25-2013, 07:21 PM
ComputerCowboy's Avatar
ComputerCowboy
ComputerCowboy is offline
They didn't change the frames, you should not have a problem running suspension from an '05.
Check out this recent thread, it is similar to what you want to do.
https://www.ford-trucks.com/forums/1...nto-an-ex.html
  #32
Old 08-25-2013, 08:09 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by sandman6
does anyone know if they changed the frame of the excursion or its suspension mounting points when they changed the fronts to coil overs in 2005?
Ford didn't change the fronts to coil overs on the Excursion in '05. That Excursion with coils is a two-wheel drive Excursion. Two very different front suspension setups.
Stewart
  #33
Old 08-26-2013, 01:37 PM
sandman6's Avatar
sandman6
sandman6 is offline
Thanks stewart and Cowboy for the info and links . looks like there is nothing but fear and good judgment standing in my way!
  #34
Old 08-26-2013, 03:00 PM
ComputerCowboy
well you should really take Stewarts advice and see if the kit was for a 2wd, if it was you don't want it.
  #35
Old 08-26-2013, 07:38 PM
sandman6's Avatar
sandman6
sandman6 is offline
it is off a 4x4 ( still mounted on the frame and axels) i'm going to take a lot of pictures before I remove it
  #36
Old 08-28-2013, 10:50 PM
medina525x's Avatar
medina525x
medina525x is offline
4wd Low
its been almost two years since i first started this thread lol
installed the lift 11/10/11 and I ended up getting the procomp 6" and
37'' toyo mt's on 17'' wheels. All in all I its pretty bad *** but still had to make some
adjustments up front for clearance...
Now im lookin for driverside front and rear doors just wrecked it pretty bad
this last weekend...its killin me to see it in the driveway all smashed up..... any help
or leads please
  #37
Old 01-04-2014, 05:20 PM
Dogmann's Avatar
Dogmann
Dogmann is offline
Great informative thread. Let's see the pics !
  #38
Old 10-13-2015, 11:45 PM
RRTREE's Avatar
RRTREE
RRTREE is offline
04 X with 6" BDS 37×12.50×17 cooper STT M/T's
6" BDS 37x12.50x17
Minor trimming on inner fender and no more rubbing.... Except when a Honda some how did not see me next to them in an intersection and drove under me and my tire ended up in there door window.
  #39
Old 09-24-2019, 05:23 PM
05XCRSN's Avatar
05XCRSN
05XCRSN is offline
Hate the ROUGH COUNTRY 3 inch lift. Way too stiff and has dropped significantly.
04 6.0PSD $20k Various worn out suspension parts replaced REDHEAD steering box 3 in ROUGH COUNTRY lift F-250 rear springs Moto metal melee 22x10 -18et w/ 35x12.5 fuel gripper tires Nerf steps. Up next.. 4 inch straight pipe 05 facelift Window tint
I'll try the BDS 6in leafs. Is yours a diesel?
  #40
Old 09-24-2019, 05:34 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
be forwarned this is an 8 year old thread with a bunch of bad info in it, i would not use RC suspension stuff if it was free
  #41
Old 09-24-2019, 05:42 PM
05XCRSN's Avatar
05XCRSN
05XCRSN is offline
Agreed
The local shop recommended the RC kit. Ugh.
  #42
Old 09-24-2019, 05:47 PM
pirate4x4_camo
probably because that is what they sell
start s new thread.
include your current setup info with hub to fender measurements. from center of hub straight up to bottom of fender arc.
what you want your final ride height to be
what size tire
any additional goals or improvements or ride quality and handling issues you may have.
this isnt that hard, we have answers
  #43
Old 04-07-2020, 11:19 AM
msuforeman's Avatar
msuforeman
msuforeman is offline
start s new thread.
what size tire
I have a 2005 V10 4x4 with 191k miles that I would like to run 35" tires. I don't really care if it rides like a truck. I will be adding either a whole winch bumper or winch mount with a Warn 12k winch in the near future.
23" up front and 24" in the rear
Thanks in advance.
  #44
Old 04-07-2020, 02:24 PM
Lance Helmert's Avatar
Lance Helmert
Lance Helmert is offline
Start a new thread of your own.
  #45
Old 06-26-2020, 11:59 AM
78CJ5's Avatar
78CJ5
78CJ5 is offline
Originally Posted by gotgig
If you decide to go with a 4" lift you might want to check BDS. I have the BDS 4" all spring lift and like it a lot. I'm running 35s on 18" wheels.....
HI gotgig.
Question, what is the correct off-set to use? I just got a 2002 Limited, V10, 4x4, 150K with a ProComp 4" lift. The guy that had it also put on 35x12.5x20's. I hate to 20" as they ride harsh. He didn't get the right rims as they hit the springs on tight turns. So I'm planning on going to 17' or 18's with 35c12.5's. So I'm trying to find the correct off-set.
Thanks for whatever help you can give me.
David Phelps
Magalia, CA
Quick Reply: Excursion Lift Kits / Which One?
