0fficial 7.3 MPG
Example trip from mid-Alabama to central KY. First 125 miles at 55-65 state highways, next 75 miles or so at 70 on the interstate, then dropped back to 65 for the remaining 300 miles. Arrived at destination with trip computer showing 20.3 mpg. Filled up the next day and verified that was accurate to within a couple of tenths (hand-calculated at 20.1).
Trip back, same speeds for same distances but with about 600 lb. of stuff in the bed. Pulling into the driveway said 19.8 mpg. A tad windy most of the trip back.
That includes the hills of northern TN and southern KY on I-75.
My "city" driving is mostly rural, so I manage to plug along in the mid 18's on a normal basis. I've seen 16.8 - 17.3 when having to spend a lot of time in town (we have really long stop lights).
1999 SD F250, ext cab, 8" bed, 8,000 pounds, 7.3, 6 speed manual, 3.73 rear, 305/70 tires..............19 mpg with the motor turned up on I-10 here in Louisiana........22 mpg sightseeing in the rockies in Colorado with the motor back in stock tune. 12 mpg towing a travel trailer with the aerodynamics of a parachute or a brick turned sideways. All this with 278,000 on the odometer
My 2002 350 shortbox crewcab at 72 mph and almost 2200 rpms is getting 14.4. That's four hundred miles into it and nothing but. A quarter city driving and three quarter straight flat road cruise control on 60 is 16.2 mpgs and the best I've ever gotten is 18.8. All hand calculated. Although lie o meter was never far off by .3 or .4. I have a superchips tuner, a 6637 air filter kit setup with the big boost air filter, a four gauge pillar pod and that's it besides a 3:73 rear end with 4x4. and recently my mpgs have dropped 1 mpg to 2 mpgs so I highly suspect a clogged epbv tube. I cleaned it out about 8 months ago, but still suspect the tube for for these 13.9 and 14.2 attrocities. Stop rollin so much coal, clean your epbv tube, get the right tire set up for mpgs, take care of boost leaks and these should get you right around 14 to 17 mpgs. Anything above that is an above average, highly maintained work of art. Which is what I consider mine everytime I turn that key and it fires up light its never been touched god blessed america and god blessed these 7.3's.
I weigh in at 7050lbs and on 285/75/r16 Cooper Discover STTs I'm seeing 14-16mpg.
Rustbucket (Ford F-350 Super Duty) | Fuelly
2wd trucks get a few MPG more. But... then they lose that fuel efficiency in winter when they're idling in one spot so the driver doesn't freeze while they wait for a 4x4 to come pull them out of wherever they're stuck at.
I change the oil twice a year, regardless of mileage, only God knows how it was maintained before I aquired it a year and a half ago. Everything on it is original, cept for the Turbo (I think) I check the oil every two weeks, if I think about it. "Highly maintained" ? Not this truck.It gets no special treatment. 19 mpg is what it averages, everytime I check it down here (sea level) I suspect those that are getting 13-14 are mostly automatic transmission trucks, although I haven't really read thru to see. That's the main reason I turned away from an auto truck, I passed on a 99 that had 100K fewer miles, but it had an automatic, it was only a matter of time before I'd have to fork over 3-4 grand to go thru the trans. Great thing about the manual is clutches will last forever, if you do not abuse em and shift without using it. I spent $500 on a new clutch, flywheel and pressure plate a few months after buying the truck, I figure that's all I'll have to do to that part of the drivetrain for another 10 years.
