Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 10-21-2011, 01:57 PM
hodges710's Avatar
hodges710 hodges710 is offline
Garage is empty, add now
hodges710 is starting off with a positive reputation.
Heater control valve
Where is the heater control valve at on a 1998 Expedition (4.6). thanks
  #2 (permalink)
Old 10-21-2011, 03:17 PM
pdqford pdqford is offline
pdqford is gaining momentum as a positive member of FTE.pdqford is gaining momentum as a positive member of FTE.
There's a heater control valve?
__________________
Jim in Central NY
'79 2WD F-150 Lariet w/302,4spd OD, 228,965 mi. (Original Owner!)
'02 4X4 Navigator w/5.4L DOHC 32v Intech V-8 (VIN R).
http://www.fuelly.com/sig-us/50500.png
  #3 (permalink)
Old 10-21-2011, 04:29 PM
TerryB99 TerryB99 is offline
2000 Lincoln Navigator
My Garage
TerryB99 is starting off with a positive reputation.
I do not think most Ford's have one. I think coolant flows thru the heater core all the time.
Maybe better than having coolant just sit in the heater core all during warmer months
__________________
Terry
2000 Lincoln Navigator 4WD 72K miles
2000 Grand Marquis LS 117K miles
  #4 (permalink)
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
I don't believe there is a control valve per se. The engine coolant is always circulating throughout the system and the infamous blend door controls the heat or cooling you get in the cabin of the truck. I believe there is a vacuum operated valve on the F250's and Excursions, but not sure. You may have to repair the blend door and there are many posts regarding this.
  #5 (permalink)
Old 10-22-2011, 05:56 AM
hodges710's Avatar
Thanks for the replies, I have found outt hat there is no HCV and I have already visualy inspected the blend door and it works good. I believe i am going to think i have a clogged heater core and/or line. thanks
  #6 (permalink)
Old 10-22-2011, 07:50 AM
Moto Mel's Avatar
You might try reverse flushing the heater core to clear it. Have you ever used any kind of radiator stop leak stuff in your truck?
  #7 (permalink)
Old 10-22-2011, 08:32 AM
hodges710's Avatar
Quote:
no I have not use any kind of stuff like that, I will do the flushing and see what comes of it. With the rear unit, is there anything to do or should i flush the whole deal for the heat in rear is alittle warmer than front but nothing you would want to be in a long time in the winter in the new england area. thanks
  #8 (permalink)
Old 10-22-2011, 08:39 AM
Moto Mel's Avatar
I would try flushing the whole system with plain water. I am not a fan of the corrosive radiator flush products as they can cause even bigger problems. It could be something as simple as a blockage at the hose connection at the engine or in the hose itself.
  #9 (permalink)
Old 10-22-2011, 08:52 AM
hodges710's Avatar
Thanks
Tags
03, 2002, 2003, 60l, 99, control, expedition, expedtion, fix, ford, heater, lincoln, navigator, sport, trac, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
