What is normal EGT temperature?
Old 10-21-2011, 08:50 AM
LRSTony's Avatar
LRSTony
LRSTony is offline
i tried a search but didn't find much. i'm just curious as to what my normal egt's should be while highway driving and while towing. i have an 05 excursion with the 6.0, it has a 4" exhaust all the way back, cold air kit and is running a tow tune. during normal highway driving i am usually in the low 800's but if i accelerate i will rise into the 900's is this normal? i haven't done any towing yet with my new gauge so i'm not sure of those temps are but for some reason i just thought the temps for normal non-tow driving would be lower. anyone know what the normal temps are for my application?
Old 10-21-2011, 09:15 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
05 f250 6 inch lift is offline
Not sure what tuner ur using. But with my bullydog on performance my EGT temp are in the 800's on highway not towing. An when u step on the GO pedal ur temps will go up.
While towing a 7300 to 7500 pound load my EGT temp have been up in the 1200 to 1290 range.
I have hit temps of 1380 unloaded before. Just all depends on how hard an for how long u hold the GO pedal.
Old 10-21-2011, 10:15 AM
SixGunCaliforniaKid's Avatar
SixGunCaliforniaKid
SixGunCaliforniaKid is offline
Strait out of the 6.0 tech folder:
https://www.ford-trucks.com/forums/9...-pressure.html
Old 10-21-2011, 02:22 PM
LRSTony's Avatar
LRSTony
LRSTony is offline
thanks guys!
Old 10-21-2011, 05:25 PM
Airzima's Avatar
Airzima
Airzima is offline
LRSTony,
Is your EGT probe is located in the exhaust manifold or the Turbo downpipe. There is about a 300 degree difference in the temps between the 2 locations. The exhaust manifold being the higher temp.
sur48
1999 to 2016 Super Duty
05-05-2019 08:37 PM
lewis racing
09-02-2014 09:32 PM
i eat hybrids
04-19-2011 07:02 PM
notsoswwuyd
05-09-2005 04:19 PM
donnoel
09-19-2003 04:11 PM
Quick Reply: What is normal EGT temperature?
