7.3 Fuel sending unit fixed, not replaced... - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-21-2011, 02:35 AM
lllateralus lllateralus is offline
lllateralus is starting off with a positive reputation.
Just thought i'd post this to possibly save someone out there a boat load of money like I did.
I almost went to the dealer and purchased a new fuel sending unit but decided to try something just for kicks, and boy am I glad I did.
First off, I posted a few days ago stating that I ran my truck out of fuel with the gauge showing 1/4 of a tank of fuel.
The sending unit had failed.
Today I dropped the tank, and just before running out and giving the stealership almost 500 bucks, I grabbed my can of "Mass Air Flow Sensor Cleaner" spray.
It is a high pressure spray can, similar to carb cleaner but I imagine, not NEARLY as harsh.
I sprayed tons of the stuff in and around the plastic sending unit sensor area where the fuel float up and down "action" takes place. (like the pivot point, where the sensor ITSELF is located)
I let the stuff dry fully, and started running some tests positioning the float wire in different positions and cycling the ignition, including at very low levels where the fuel light is ON, where it would not correctly indicate before.
I put her all back together and all seems normal.
Old 10-21-2011, 04:43 AM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
Very interesting, good to know. Thanks for posting!
Old 10-26-2011, 03:15 AM
***UPDATE***
Well, it was reading accurately for about 4 days. This morning, I knew when I started the truck that I did not have as much fuel as the gauge was indicating. Dang it...
Well, looks like its time to drop the tank again and replace the sending unit.
My question is, why is the diesel sending unit 3 or 4 times the cost of the non-diesel unit? This little sending unit is nearly 400 bucks.
I simply cannot afford that right now.
Old 10-26-2011, 04:30 AM
Bummer. Might see what a used one would cost at a junk yard...?
Old 04-22-2014, 04:31 AM
Viper9087 Viper9087 is offline
Viper9087 is starting off with a positive reputation.
Just wanted to toss this in here... (better late than never)
My sending unit had corrosion and rust on it an ultimately failed.
The same thing happened with my 78 f-350 after purchasing it not running with 5 gal of water! in the fuel tank. (looked like a cavern of rust icicles up to 5" long in the tank) Well after replacing the entire fuel system (lines, tank, pump, carb) I found that the dump body i had, used a custom side mount tank. Nobody made a replacement sending unit. What to do?... Well, I pulled it disassembled it to expose all of the contacts and ran it through my sand blaster. Soaked it in wd-40 bent any loose contacts back to grip better, put it back in and now 2014 still works like a charm.
Same thing happened to my 02 F-550 Read 1/4 when empty and empty when full. Pulled it out sand blasted the inside, reassembled and works like a charm again. Transfer Flow discontinued the part for my tank and oem one (if i could get it to fit) would have been over $400.
So save yourself the money and give it a shot If you don't have a blaster toss a guy $40 to hit it for you. Well worth it. Also keep it lubed by adding Marvel mystery oil or ATF once in a while to the tank if your running a gas engine. ( I usually do this once a year in the summer)
Need help, Fuel tank is on the floor garydmundy 1999 - 2003 7.3L Power Stroke Diesel 7 07-15-2016 05:14 PM
new fuel gauge float unit not working jim collins 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-10-2015 08:25 PM
92 bronco 5.0l - New fuel system but won't start 75_92_95 1978 - 1996 Big Bronco 13 07-22-2015 08:47 AM
Fuel Tank sending unit info elroy6468 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 05-13-2015 04:23 PM
1990 f150 fuel sending unit and float gissmo2 1987 - 1996 F150 & Larger F-Series Trucks 1 03-18-2014 07:34 PM
Tags
1999, 2005, 97, 99, diesel, duty, f250, ford, fuel, powerstroke, removal, sending, super, unit, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
