Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 10-20-2011, 10:21 PM
pkorrupted's Avatar
pkorrupted pkorrupted is offline
Garage is empty, add now
pkorrupted is starting off with a positive reputation.
axle ratio question
I have a 1959 F250 292 V8 4speed 2wd truck. I am trying to figure out my axle ratio. It is a full floating Dana 60. There is no axle tag on the pumpkin but it does say 60 on the side of the pumpkin. The VIN tag says 04 for the axle. I have searched all over and cannot find this ratio.
  #2 (permalink)
Old 10-20-2011, 10:45 PM
pkorrupted's Avatar
http://www.ford-trucks.com/forums/me...-imag0136.html
Click for image of VIN plate
  #3 (permalink)
Old 10-20-2011, 10:57 PM
ibuzzard's Avatar
ibuzzard ibuzzard is online now
In Memoriam.....
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
PK, I think there were only two gear ratios available for the Dana 60 rear-ends in our 1959 F250.One was 4.56:1, which is what had,and also (I believe) 4.11:1.Not positive on the second one.
I had the gears changed to a more friendly 3.54:1, if I lived in a flat area,would have even went to a 3.23 for better fuel mileage.
Note: I saw where you listed your axle code,04,that means you've also got the 4.56.
Steve
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Entitled, self-absorbed kids - meh."
  #4 (permalink)
Old 10-20-2011, 11:03 PM
pkorrupted's Avatar
That's what I was thinking for ratio but I was hoping it was 4:11 not 4:56. 1st gear is absolutely useless and 60 mph is almost on the rev limiter. I am gona definitely get 3:54 gears. That is the lowest ratio I can find of any brand. Are you sure 04 means 4:56 or is that just and educated guess? Thanks
  #5 (permalink)
Old 10-20-2011, 11:06 PM
ibuzzard's Avatar
In Memoriam.....
That is according to the chart in the 1959 Truck Parts and Accessories Catalog that I have.
__________________
  #6 (permalink)
Old 10-20-2011, 11:11 PM
pkorrupted's Avatar
Thank you very much. I need to get one of those parts catalog.
  #7 (permalink)
Old 10-22-2011, 11:34 AM
pkorrupted's Avatar
So, since I have 4:56 gears does that mean if I went with 3:54 gears I would have to get a 4:11 and lower carrier? Will 3:54 gears fit on my 4:56 differential?
  #8 (permalink)
pkorrupted's Avatar
  #9 (permalink)
Old 10-22-2011, 11:43 AM
ibuzzard's Avatar
In Memoriam.....
PK,I took my truck to a reputable truck/4-wheel drive shop that did the work quickly,efficiently for about 350.00 ,about 4-5 years ago.They had the correct gearset in stock,they do lots of these change-overs.If you're in a smaller town,though,any good shop can order the parts.I'm in Cali,so what might seem an outrageous price to you guys in other parts of the country,to me is a bargain.Possibly less expensive in other areas.
Steve
__________________
  #10 (permalink)
Old 10-22-2011, 11:49 AM
pkorrupted's Avatar
But im still wondering if there are two different differentials for the 4:56-up gears and 4:11-down gears. Will the 3:54 gears work on my 4:56-up differential or do I need to get a 4:11-down diff?
  #11 (permalink)
Old 10-22-2011, 11:56 AM
ibuzzard's Avatar
In Memoriam.....
The exact same Dana 60 housing for the F250(3/4 ton),and will accept different gearsets.AFAIK,it was the only available differential from Ford for an 2WD F250 in 1957-60.Of course, who knows what some deranged previous owner may have thrown in there,then all bets are off.Run it by a good shop,they'll quickly I.D. it for you if you're not sure.
__________________
  #12 (permalink)
Old 10-22-2011, 03:27 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
the 2 ratios used on F250 2WD trucks are 4.56 and 4.88...
- cs65
  #13 (permalink)
Old 10-22-2011, 03:56 PM
ibuzzard's Avatar
In Memoriam.....
Quote:
- cs65
Thanks for correcting me,Don
Steve
__________________
  #14 (permalink)
Old 10-22-2011, 04:27 PM
pkorrupted's Avatar
Thanks guys. I just wanted to make sure if I order 3:54 gears they will work on my diff.
  #15 (permalink)
Old 10-22-2011, 08:13 PM
mr4speedford's Avatar
mr4speedford mr4speedford is offline
mr4speedford is starting off with a positive reputation.
You might want call one of the bigger axle part companies and ask, I know the dana 44's in the early trucks used two carriers depending on ratio. I'm willing to bet the 60 is the same way.
__________________
My two favorite things in life:
Y-blocks with smitty's, and girls with big.....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
