'03 Powerstroke misses and runs rough.
Old 10-20-2011, 09:08 PM
memarkers's Avatar
memarkers
memarkers is offline
'03 6.0 Powerstroke. Rough idle AFTER it warms up. Runs fine cold. It seems to studder and miss at mid range acceleration. Egr deleted and new oil cooler installed. New lift pump. Replaced ICP sensor. Have 48.5 volts at the FICM. Replaced the fuel pressure spring to the blue one. All new filters. Does not smoke. Does not throw codes. I need to fix this truck one last time. It has a date with the bottem of a very deep lake! It has been nothing but a pos since it hit the ripe old age of 25k miles! Please help me drown her!
<!-- / message -->
Old 10-20-2011, 09:19 PM
hotroddsl's Avatar
hotroddsl
hotroddsl is offline
Just give her to me! I'll be happy to take over the problems for ya'... What are you running for oil? Have you considered running an additive such as Hot Shots Secret? Or one of the others? Have you checked the unison ring for binding? Could be a striction issue I would look tword injection but otters will come along with their input as well, I don't think the lake is nessecary just yet!
Jim&fat Monty
Old 10-20-2011, 09:24 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.0L Powerstroke Diesel forum.
Old 10-20-2011, 10:00 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
did you use a motocraft oil filter and stock cap
Old 10-21-2011, 01:30 PM
memarkers's Avatar
memarkers
motorcraft filter and original cap.
Old 10-21-2011, 01:34 PM
memarkers's Avatar
memarkers
i am changing the oil today and adding HSS to see if it is stiction. Just cant understand why it runs fine until it warms up and then sounds like one or more injectors are not working. Should be the other way around. Runs bad cold then warms up and runs better.
Old 10-21-2011, 01:53 PM
NewToDiesels's Avatar
NewToDiesels
NewToDiesels is offline
Could possibly be your FICM acting up when it gets warm. Have you tested it using the FICM test procedure in the Tech Folder? I would test it cold, and then test again when she's warmed up good.
Old 10-21-2011, 02:06 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Could be a Ficm like Alan said but those usually get better as the truck warms up check it out Just like he said
I dont think changing the oil will help but couldnt hurt
Stiction goes away as the truck warms up thats a cold running issue
I think that it maybe an injector harness
any smoke
any gauges
Old 10-21-2011, 02:34 PM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
I agree with you totally.
My truck did the exact same thing, ran excellent cold, once it warmed up...rough running same symptoms as you.
Turns out one of my ficm plugs was slightly loose.
Test your ficm/check connections
Old 10-22-2011, 10:40 AM
memarkers's Avatar
memarkers
FICM tested out to 48.5 cold and hot. Almost no variation in the reading. Thinking now to check the IPR.
Old 10-22-2011, 11:12 AM
memarkers's Avatar
memarkers
unplugged the icp no change. time to go to the shop. i give up!!!
Old 10-22-2011, 11:18 AM
NewToDiesels
It boils down to how much time you have... A good Ford tech can usually find your problem pretty quickly. They can do a diag for you for about $100 and then you could fix if you want to tackle it. That saves you a lot of time on the front end troubleshooting the issue.
Old 10-22-2011, 11:45 AM
kev966's Avatar
kev966
kev966 is offline
sounds to me like when it warms up, the oil thins a bit and escapes through a developing leak in your high pressure oil system. Same problem I had, with same symptoms
Old 10-22-2011, 11:48 AM
kev966's Avatar
kev966
kev966 is offline
after it warms up, if you shut it down , are you able to restart with no problem?
Old 10-22-2011, 11:52 AM
memarkers's Avatar
memarkers
yes, after its warm it starts fine it just misses bad. It starts and runs great cold. I just don't get it. I have or had 3 6.0 trucks but this is the only early build and the only one with all of these problems. I'm going back to riding horses!
Quick Reply: '03 Powerstroke misses and runs rough.
