Installing brake controller on older truck - Ford Truck Enthusiasts Forums
Old 10-20-2011, 09:02 PM
snowdog79's Avatar
snowdog79 snowdog79 is online now
snowdog79 is gaining momentum as a positive member of FTE.
We have a '94 Bronco that I want to install a Prodigy P2 that I am taking out of my '07 F150. It currently has a 6-pin harness that I will switch to a standard 7-way. Does anyone know if the '94 and up harness that Tekonsha sells is plug and play on the Bronco? Not looking forward to this...
Old 10-21-2011, 09:07 AM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Can't answer that question, however I would recommend you go with the P3 unless you have a trailer that has electric over hydraulic brakes.....
Tekonsha has a good web site or a call to them will answer your question.
Old 10-21-2011, 02:41 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
According to Tekonsha's web page, the wiring adapter they have is for 94-96 Bronco's, so their should be a plug under your dash that fits the direct wiring adapter.
Brake Controllers - Tekonsha
Old 10-22-2011, 09:41 AM
snowdog79's Avatar
Looks like I'll be able to use the adapter I have for the '07. Now I just have to sort out the brake wiring at the back of the truck. Thanks for the help, guys! Going to miss the F150.
ecu confusion biofused1 Fuel Injection, Carburetion & Fuel System 2 02-03-2015 02:42 PM
89 2.9 Bronco II to 4.0 Engine swap pianoman Engine Swaps 4 05-16-2008 09:18 AM
98 Explorer Overhead Console wiring diagram ? 80Bronco94 Explorer, Sport Trac, Mountaineer & Aviator 2 10-21-2005 09:45 PM
94 f-150 5.0 efi install in 66 bronco jwgriffith Engine Swaps 9 07-06-2004 06:39 PM
94 Bronco Amp output diagram? jeffscott Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 12-05-2003 09:24 AM
Tags
89, brake, controler, controller, f150, install, installing, older, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
