1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
New to the Unibodies
Old 10-30-2011, 09:33 AM
cwindsor's Avatar
cwindsor
cwindsor is offline
Hello,
Just getting inti the Unibodies for the first time. To tell you a little about my truck, I have a 61 Unibody with a 289 on a C4 Trans. its has headers, 12 volt system, dual flows, 4 barrel Holley, little rust... only in the common places.
issues I am working on right now are Gaskets (of course)... C4 won't go into 3rd.. finding agauge cluster that works.. MPH broke, and getting the Sterling tighter...
The steering seem to have a bit of play in it and scares me a bit at higher speeds..
Thanks for reading.
Old 10-30-2011, 09:01 PM
cwindsor's Avatar
cwindsor
cwindsor is offline
Well just found out the blower motor is bad and the whole bottom of my tail is built with bondo....
Old 10-30-2011, 09:06 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
That Sucks. Lets see some pics anyway.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Gear Up
04-15-2013 09:58 PM
karjunkie
27
10-02-2012 10:34 PM
STROKED-OUT
04-21-2012 10:24 PM
moose79
16
05-07-2011 05:46 AM
flyin 51
04-26-2011 10:06 AM
Quick Reply: New to the Unibodies
