Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-19-2011, 05:08 PM
DrainBramage DrainBramage is offline
Garage is empty, add now
DrainBramage is starting off with a positive reputation.
Dual snorkel air cleaner retrofit question
I wasn't sure where to post this, so I figured I'd start here in the Intakes, Filters and Ram Air section.
I quite accidentally stumbled across a dual snorkel air cleaner the other day, very much like what you would find on a 85 Mustang GT or a carburated 460 pickup:
Click the image to open in full size.
Random pic from the internet for reference.
I thought it might be a fun/different project for the truck, and I like the idea of the dual snorkels to get some cooler air into the engine. I don't expect much of a mileage or performance increase. My question involves how to hook up the vacuum motors for the heat riser flappers. Bear with me while I try to explain what I'm thinking here...
I've eliminated the EGR on my truck but I still have the thermo vacuum switch stuck in the coolant crossover in the intake manifold. I'm thinking I can plug one side the switch into a manifold vacuum source and T the other side to the pair of vacuum motors that control the heat riser flappers. I'll be building a pair of hot air stoves to pull heated air off my exhaust. This configuration should supply hot air until the coolant warms up to the point where the thermo switch opens and pulls vacuum on the motors, closing the flappers. I should get nice cool ambient air through the snorkel ducts as long as the engine is warmed up.
So, does that sound like it will work?
Thanks for the input!
__________________
1973 F250 2wd Camper Special - 390FE, 600cfm Autolite 4100, DSII w/MSD 6A, NP435, Dana 60 4.56:1 open - haulin' beast (66.6k mi 7/24/11 )
1966 Mustang - built 302, 480cfm Autolite 4100, B/W T5, Currie 8" 3.55:1 LSD - in pieces
1974 Bronco - 302 2v, C4, D20, D44, 9" - 'consulting mechanic' (Brothers project)
1974 Triumph TR6 - 2.5 I6, Twin ZS175CD carbs, 4spd, Panasport 15x6 - the 'fun' project
  #2 (permalink)
Old 10-27-2011, 09:33 PM
rikard rikard is offline
1995 Ford F-150
rikard is gaining momentum as a positive member of FTE.
I fabricated one on one of my GMs and used the temp control in the air cleaner to operate both. It was more for looks and it was a conversation piece and I'm pretty sure it didn't add any power. I was able to adjust the vac temp controller to about 50 deg from the stock 100. I also thought about using a coolant temp switched vac source as plan "B" but I wanted some heat to keep temp above 40.
regards
rikard
__________________
"Be who you are and say what you feel because those who mind don't matter
and those who matter don't mind."
- Dr. Seuss"
Nelly Belle 1995 Black F150 4x2 SC XLT 300 5 Spd 242k
Tags
1963, 2011, 60, air, cleaner, diesel, dual, dualsnorkelaircleaner, duty, f250, large, mustang, snorkel, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
