1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Found a unibody, need info
Old 11-17-2011, 11:37 AM
krazyasslunatic's Avatar
krazyasslunatic
krazyasslunatic is offline
It's a long bed v8, had ford on valve covers and looked like an equalizer? Pipe going from one exhaust manifold to the other, it's 8 lug also, how rare would this be? Were all 61 to 63s unibody?
Old 11-17-2011, 08:00 PM
fivestarmmd's Avatar
fivestarmmd
fivestarmmd is offline
What have is not unusall 292 V8 known as Y block. 3/4 ton pretty standard. Not all were unibodys they made flareside beds,caband chaiss,wrong box 57/60 bed used on 4wd. Some 2wd came that way too. Should have bought the one I found 25 years ago.
Old 11-17-2011, 08:21 PM
krazyasslunatic
This ones sitting in a yard kind of out in the country, body looked straight, last tagged in 1983
Old 11-19-2011, 09:54 AM
64blue's Avatar
64blue
64blue is offline
I changed mine over to use the ramhorn manifolds instead of the cross-over. It gives me better sound and look. I'm also using porter mufflers which are great.
Old 11-19-2011, 10:29 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Old 11-19-2011, 10:35 AM
kjvforme's Avatar
kjvforme
kjvforme is offline
If the door is unlocked the warranty plate with VIN will be on the inside of the glove box door. Shoot a close up picture of it and we'll give you more information about the truck.
66with352
10-27-2012 08:22 AM
old broke prospector
06-20-2012 09:59 PM
speedracer1000
09-10-2010 07:28 AM
modeleh
09-23-2008 01:53 AM
whitfimb
04-27-2003 01:25 PM
Quick Reply: Found a unibody, need info
