Coolant Line Diagram - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 10-19-2011, 09:36 AM
sddesigns's Avatar
sddesigns sddesigns is offline
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
Anybody have or knows of a link for a diagram of the coolant lines around the heater core, 2001 V10 4X4?
I have a leak that just started somewhere between the passenger side manifold and the firewall, I can't see exactly where it's coming from, but as soon as it builds pressure it sprays the manifold which causes it to steam. It drips down onto the rear of the front passenger side spring perch, so isolating it when its leaking is tough.
Old 10-19-2011, 09:50 AM
housedad's Avatar
housedad housedad is offline
housedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputation
This is the best I have, Steve. Hope it is enough. From the 2005 Service manual for v10
S5P~us~en~file=S5PC2004.pdf~gen~ref.pdf - PDF Archive
Click on the download file part to download the pdf
Old 10-19-2011, 10:05 AM
sddesigns's Avatar
Thanks Bion!
I think that might be what I was looking for, I'll check later when I get home!
Just hope the rain stops, it's really coming down up here!
Old 10-19-2011, 10:18 AM
housedad's Avatar
Quote:
Originally Posted by sddesigns View Post
Thanks Bion!
Raining like hell here in South Jersey too. Cold, pain giving rain.
I have had a LOT of broken bones and I'm eating Ibuprofen like candy.
Sore head to foot on days like this.
Old 10-19-2011, 10:37 AM
sddesigns's Avatar
Sorry to hear, hope it clears out fast!
Old 10-22-2011, 11:37 AM
sddesigns's Avatar
Found the leak from the diagram you provided, if you look at the second page top left drawing, that hose connects to a metal tube on the back side of the motor and loops back under the intake manifold going to the water pump. The leak is the metal tube on backside of the motor before it bends back forward.
Old 10-22-2011, 11:54 AM
housedad's Avatar
Thankfully you found it.
now to find the dang part, eh?
Old 10-22-2011, 12:03 PM
sddesigns's Avatar
I found a post here in the Expedition/Navigator forum.....http://www.ford-trucks.com/forums/75...ml#post6359125
Old 10-22-2011, 12:23 PM
housedad's Avatar
Ain't this place grand?
FTE. the place to fix your truck!!
Old 10-22-2011, 01:27 PM
wildstang's Avatar
wildstang wildstang is offline
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
So it is the metal tube? Much better than heater core.
Old 10-22-2011, 03:58 PM
sddesigns's Avatar
Here are the parts I ordered today to hopefully fix this issue...
(1) #4C3Z-18663-CA Heater Tube - Long tube that goes from the other end of the hose on page 2 (top left picture) to the water pump.
(1) #F75Z-8555-AA Tube Assembly - this piece has the fitting that goes into the back of the water pump and attaches to the tube.
(2) #N811415-S309 Stud - these are what hold what looks like tabs on the tube at the back of the block (these were ordered just in case).
Just a thought brought up in another thread, what other items will be needed, IE...new intake gaskets, o-rings, special tips or tricks to remove the intake manifold and adjacent parts to get to the heater tube?
Old 10-22-2011, 07:41 PM
GIGGER's Avatar
GIGGER GIGGER is offline
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Looks like you've been buisy Steve
Old 10-24-2011, 09:49 AM
67nukeford's Avatar
67nukeford 67nukeford is offline
Nebraska Chapter LDR
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
Hopefully that takes care of it Steve. Looks like it will be fun replacing all of that.....NOT!
Old 10-28-2011, 11:06 PM
sddesigns's Avatar
Well the coolant leak has been fixed, it was a pin hole on the tube opposite the nipple return, the cause looked to be sediment having a sand blasting effect inside the tube. The first picture shows the tube and the next one shows a closeup of the hole. The next picture just shows where on the back side of the water pump the tube connected.
The entire intake manifold had to be removed, it took about 5 hours from start to finish.
Old 10-28-2011, 11:10 PM
GIGGER's Avatar
Posting Legend
Well done Steve & cudos to your buddy with the shop
Vaccum pump running steventothemax 6.0L Power Stroke Diesel 7 09-16-2011 02:02 PM
coolant crossover tube leaking psd77066 Expedition & Navigator 5 09-07-2009 08:46 PM
5.4 coolant leak at the intake Superdave Modular V8 (4.6L, 5.4L) 4 06-11-2009 09:25 PM
5.4 coolant leak at the intake Superdave 1999 to 2016 Super Duty 13 06-10-2009 02:34 AM
5.4 coolant leak/intake problem ? HELP !! beel61 Modular V8 (4.6L, 5.4L) 1 05-20-2009 08:10 PM
Tags
2003, 2005, 2008, 54l, 64, 73, coolant, coolent, diagram, diagrams, diesel, escape, excursion, f250, ford, line, lines, return, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
