pre bent stainless brake lines - Ford Truck Enthusiasts Forums
Old 10-18-2011, 09:42 PM
kingford72's Avatar
kingford72 kingford72 is offline
kingford72 is starting off with a positive reputation.
Has anyone ever taken a line set meant for a F100/F150 2wd and used it for a F350. No one seems to list a brake line set for anything other than a 1/2 ton truck. If someone has the time, I would appreciate it if they could let me know what the fitting sizes are, and there location on the proportioning valve of a F100/F150 2wd truck, so I can reference it with mine. I'm working on a 1975 F350 2wd crew cab. Thanks guys.
Old 10-18-2011, 11:03 PM
JB78f150's Avatar
JB78f150 JB78f150 is offline
JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.
I'd say if the lines say they are meant for crew cab then I would say they would work. There are no 1/2 ton crew cabs so they must have been a typo on the site or mag or where ever your buying them. This is what I think maybe I'm wrong but If I am then its a bump to the top.
Old 10-19-2011, 06:33 AM
gregb gregb is offline
gregb is starting off with a positive reputation.
I bought a set from JBG. They are nice, but if i had to do it over again I would just buy a roll of stainless and make them myself. Would be alot cheaper and I think that I could make a cleaner looking install.
Old 10-19-2011, 06:40 AM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
To do bend and to put sae inverted flare in stainless you are going to need a bender and double flare tool rated for stainless. The regular bender and flare tools don't cut the mustard. Stainless tubing is tuff stuff.
Old 10-19-2011, 08:47 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
If you still have the originals, but they're just pitted or rusted through, you can send them in to Inline Tube and they can duplicate them.
Old 10-19-2011, 05:27 PM
kingford72's Avatar
fmc400 I thought about sending mine in but my proportioning valve is hanging out in space directly under the master cylinder, that just doesn't seem right, see this picture-
I didn't find any listings for F250 or F350, only F100/F150. The lines shouldn't matter that much, only diff would be 4x4 versus 4x2, mine is 2wd and the crew would just be a longer line to the rear the same as long WB vs short WB. Front susp would be the same configuration through F100-F350. I was just looking for some input on the fittings on prop valve and location of the valve, because I don't think ford put mine were it is(see above).
I too have worked stainless before and it does suck, your not going to do it with cheap flare tools, and Ive been told to not use tubing cutters because they make the stainless work harden.
Old 10-19-2011, 09:43 PM
fmc400's Avatar
MSEE
Oh wow; you're right, that looks wrong. That's a custom job. The PV should not hang free like that. It should be bolted to the frame, with the lines tucked away neatly. I don't think duplication is the answer here. Sorry that I can't be more helpful.
Old 10-21-2011, 11:25 PM
kingford72's Avatar
Judging by the ford shop/parts manual the PV is in the right place its just missing the bracket that bolts it to the pwr steering box. Just as the diagram is marked any of you 74-76 F100/F350 guys (particularly the F100 guys) have a set up just like this. I checked my 78 F150 4wd and the port sizes are all the same between the two PV, the only diff. is the bleeder rod (F150 pull - F350 push in).
Old 10-22-2011, 09:02 AM
kingford72's Avatar
Just cruisin around on here and found this truck, a 76 F150 has the same configuration as mine. PV is under MC and above steering box. Shame for that truck at least they got to it before it spread to the body.
Quote:
Trying to assess the damage:
1967 F100 Camper Special rear bleeder screw size? Turbo Dog 1967 - 1972 F-100 & Larger F-Series Trucks 20 01-26-2016 08:40 AM
78 F150 4x4 brake line dawgfan74 1973 - 1979 F-100 & Larger F-Series Trucks 7 08-15-2015 07:19 PM
Another brake line question, 77' F-350 & 76' F350 similarities. old blue beast 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-19-2014 09:22 AM
1966 F250 SS brake line set?? duke_boy 1961 - 1966 F-100 & Larger F-Series Trucks 6 06-11-2011 03:16 PM
Need rear brake line fitting size and length,94 ? crashed13 1987 - 1996 F150 & Larger F-Series Trucks 2 10-20-2008 10:45 AM
Tags
2004, 72, bent, brake, bronco, diagram, f100, f150, f350, ford, lines, pre, stainless, tk, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
