F3 Axle Housing Wanted
I am in the process of acquiring the parts to build an old school Franklin quick change. I have one ring side axle housing and I need a second. I live in Jonesboro, AR and frequently travel to Memphis and Little Rock. Will be traveling to the Dallas area next month. I have some F3 chassis parts and I am willing to work a trade. If you can help please send me an email or PM
Thanks for looking!!
Something to be aware of, these axles are not all alike. The earliest ones, up to mid year 1951, were narrower than the late 1951 and 1952 axles. If you check the chassis parts manual you'll see that they have different part numbers. The reason relates to Ford's change of the braking system in mid '51. They went with Bendix brakes and moved the parking brake to the transmission. You'll want to make sure that you have axle shafts that match the housings you come up with. I junked one of these a few weeks ago. But you shouldn't have any trouble finding one locally. Stu
Thanks for the info. Noticed the narrow housing when I disassembled the rear end. It came with 14" non-self energizing brakes. Must have required a lot of leg when braking to a stop with a maxed out load.
I have access to a lot of fabricating talent and grafting on an extension is not a big problem. The plan calls for 9" Ford type brake flanges and brakes. So some axle tube work is required anyway.
A greater concern is the spline count. I was planning to use the F3 ring carrier as well. But I am not sure I can get custom 12 spline 9" Ford axles from the after market. Something to check.
Can anyone tell me what the spline count is in a F2 axle?
Please keep me in mind. I am in no big hurry with this. Have you tried Meb Gregg's Auto Salvage in Jonesboro? He has a lot of stuff from that era.
1946 Ford 1 ton complete rear end / axle Not sure if this helps, but just saw this ad.
Dano78
27
04-17-2011 04:08 AM
ccbb
16
12-25-2010 07:55 PM
skipper
12-27-2004 08:54 PM
krustiy lusti
05-01-2004 09:19 PM
