My Bosh Iridium test - Ford Truck Enthusiasts Forums
Old 10-18-2011, 04:50 PM
DarrellinCeres DarrellinCeres is offline
DarrellinCeres is gaining momentum as a positive member of FTE.
I entered the banner to try out the new Bosh Iridium plugs and was given 10 of them for my 99 F250 Super Duty, Super Cab, 6.8L V10, 4x4 with 255,000 miles. Part Number 9608 (HR 6 KII 33 X)
I got them the week before my vacation trip half way across the US. I was getting it ready for the trip so I decided to try them. The plug change went without any problem. I was a little worried about it but I don't think the Autolites I took out had been in for more then 50,000. Other then a little whitening they looked pretty good.
The bosh plugs are cool looking. The small wire electrode gives the impression that the spark would be sharp and you can just make out where they welded the piece into the ground electrode.
They came pre-gapped at .044. I don’t think I’d want to mess with the gap if I thought I had to. I used a little never seize and torqued to 15Ft Lbs. Something I do like about the packaging is that all the information on gap and torque is on the box. Even gives you the angle torque (15deg) for vehicles that use that method. The box also says last 4x longer. I don’t think I’ll be leaving these or any plug in my engine for 400,000 miles. With these heads I’d probably never get them back out without a machine shop.
After the plug change it ran real good. My trip took me from California, through the Tetons, Yellowstone, over to Crazy Horse and Mt Rushmore, down the Black Hills, around the Badlands, and up to Wisconsin (to visit mom). Came back down to Indiana to visit family then a mad dash (two days with no night driving) back to California. In total about 6000 miles.
I ran into some slight pinging at moderate load. I had a Polaris 800 Sportsman X2 and camping gear loaded and if I was climbing a hill and holding speed it would ping a little but I don’t think it was the plugs as much as altitude and higher ethanol percentage. I also discovered a small exhaust leak when I got back and I have a few other things to check. Even so I never got less then 11MPG (and that was on the way back on 80 doing…..90ish. My best mileage was about 15 doing 87. I happened to pick up a big rig doing a steady 87 going east. I was able to set my cruse control to him. I kept a mileage log and averaged about 12.5 – 13MPG for the whole trip.
The truck still runs smooth even with the exhaust leak. The leak in more noticeable when it’s cold. I just recently bought the truck so I don’t have a lot of before data to compare them to but all in all not bad performance for the workout I gave them. I’m looking into the pinging. I’m also running 5 star mikes 87 Performance tune. I was able to clear up most of the pinging by using higher grade fuel.
Would I buy them? Well at the price I might shy away from them but ask me again in another 94K when I pull them and see if they need replacing. If they live up to their longevity claim then I’d just inspect them and put them back. That’s where the value would really show up.
Old 10-06-2016, 05:10 PM
I wanted to follow up on this as I agreed to do so when I got the free ones to try andI have changed the motor these were in.
I installed them at 225K the motor blew a head gasket at 340K. Never saw a loss in performance or mileage and I should have taken pictures because I could have put them in the new engine they looked pretty good for over 100K. I'd say they are a good product and work very well. Held up and seem to be good on their x4 longer claim
I bought new ones and put them in the new motor so would I use them again, yes I did.
I'll check them again in another 150K based on how the last ones looked
My Installation - Python 533 Remote Start/Alarm in 2003 F250 whiteoak11 1999 to 2016 Super Duty 12 06-03-2016 06:34 PM
Starting my 1982 F100 build IsaacJR75 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 34 04-17-2016 12:06 PM
Ugly Betty: Frame-Up Rebuild w/ a Donor tschrubb 1987 - 1996 F150 & Larger F-Series Trucks 225 08-13-2014 02:33 PM
81 F150 300-6 vacuum questions RVF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 02-03-2013 07:52 AM
Meet Gossamer orangedude Ranchero & 1961 - 1967 Econoline 13 02-22-2011 10:18 PM
Tags
96, 9608, autolite, bosch, explorer, f150, f250, ford, forums, iridium, plug, plugs, spark, sport, tract, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
