Going from captains chairs to 40/20/40 bench, how do I do this swap?
I have a 97 F250 ext cab with captains chairs and the center console. My driver seat is broken. Yesterday I got lucky and scored a really nice condition 40/20/40 bench from a 96 F250 extended cab.
My captains chairs have power lumbar but have manual adjustments otherwise.
The new bench has power lumbar and all power seat adjustments.
Will my truck have the wiring already in place for these new seats? What about holes for the bolts and the studs?
should be a bolt in from captains to 40/20/40...
You should only need a power and ground to run the motor and air pump under the sead... Worst case senerio you need to run another power wire off the fuse box under the dash and underneath the carpet to the seat. and add another pig tail to the sheet metal on the floor for a ground.
"Take a seat..."
So, someone in engineering @ Ford prepared for the captain's chairs/console combo to be a possible option for regular and/or crew cabs but apparently others in the Ford hierarchy did not see fit to make it an RPO.
dn.
You will need to retain the 40-20-40 seat pan AND the seat tracks off the seats. The 40-20-40 seat tracks sit ALOT lower than the supercab seat tracks. If you bolt the supercab seat and tracks to the reg cab seat pan, you will be hitting your head on the ceiling
Do you know which exact seat tracks are needed? Do you have a part number or something? I've been looking online and cant find these sliders anywhere... But I would like to get a part number, and then see what other applications they came in. Try to better my chances at finding some. Thanks.
If you have your regular cab 40-20-40 mounting plate, the captain's chairs (with their respective adjusting tracks) should mount right to the mounting plate. Also, these [reg. cab] mounting plates are stamped to accept the center consoles that go with the captain's chairs: There are three pre-drilled holes ready & waiting.
dn.
dn.
dgraf961ton
04-16-2009 08:30 AM
