87 F150 fuel Problems - Ford Truck Enthusiasts Forums
Old 10-18-2011, 01:53 PM
vcobler vcobler is offline
vcobler is starting off with a positive reputation.
I have an 87 F150 w/ 5.0. The truck was running fine, then wouldn't start. it turns over but won't fire. The fuel pump on the rail was not being energized. I replaced pump and filte and nothing. I checked for fuel shutoff on pasenger side and couldn't find it so replaced fuel pump relay. I then found the fuel shutoff switch on drivers side (Chilton pay attention!). Depressed button, turned key and pump is energized but still truck won't start. Can someone please help! Do I have to reset anything? What else can I try? Thanks
Old 10-18-2011, 02:24 PM
Slip ford man's Avatar
Slip ford man Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
You really need to find out if spark is present. Also, if it is, then you need to find out what your fuel pressure is. If the pressure is too low she won't start, but I would suspect spark, until you elimiate that...check for spark, or spray a little starting fluid in the intake tube, then try to start
Old 10-19-2011, 03:26 AM
Thanks for the reply
Turned out to be a bad relay out of the box.
need help no start mjtpolice76 1999 - 2003 7.3L Power Stroke Diesel 3 04-05-2014 07:54 PM
Hooking up fuel shutoff solenoid flainn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 09-23-2012 03:43 PM
'86 f-250 - won't shut off! Alex21 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 35 03-09-2011 09:09 PM
91 F150 shutoff wont restart hunter_firefighter 1987 - 1996 F150 & Larger F-Series Trucks 53 02-20-2008 01:37 PM
Fuel Pump Shutoff Switch shanaynay Explorer, Sport Trac, Mountaineer & Aviator 3 03-07-2001 10:54 PM
Tags
87, 87fordf150fuelproblems, f150, ford, fordfuelissues, fuel, problems, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
