Freon Capacity? - Ford Truck Enthusiasts Forums
Freon Capacity?
Old 10-18-2011, 02:23 PM
cgi2099 cgi2099 is offline
cgi2099 is starting off with a positive reputation.
Freon Capacity?
Anyone know the freon capacity on the a/c system for a 1981 F150 4x4 with a 351M & C6?
Old 10-18-2011, 02:34 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
It may be gone, but there should have been a sticker on the radiator support. Unfortunately, most of the computerised manuals only go back to 1983.
Old 10-18-2011, 02:39 PM
TheKirbyMan's Avatar
TheKirbyMan TheKirbyMan is offline
TheKirbyMan has a good reputation on FTE.TheKirbyMan has a good reputation on FTE.
I wouldn't think that the AC systems varied in capacity based on engine size...
FWIW, my 81 F150 with a 302/C6, 2WD and factory AC has a sticker stating that it will hold 3lbs 12oz of R12. Not sure how much R134a it will need though.
Old 10-18-2011, 05:10 PM
Herb Brooks Herb Brooks is offline
Herb Brooks is starting off with a positive reputation.
I know they vary between Diesel and gas.
Old 10-18-2011, 05:30 PM
^ Thanks for the correction.
Old 10-19-2011, 12:31 PM
Tknight85 Tknight85 is offline
Tknight85 is starting off with a positive reputation.
Should be around 3 if it's completely empty
Old 10-19-2011, 12:52 PM
Truthfully I never worry about lbs. I just get the presure right and letter go.
Old 10-19-2011, 12:55 PM
3 cans I meant
Old 10-19-2011, 01:04 PM
Understood. Also if the system is dry pull a vacuum on it for at least 30 minutes and the first thing in should be a can of oil charge. I assume you know how the freon got out and have repaired the leaks. new orifice tube etc..
Weak A/C ugh3012 1999 to 2016 Super Duty 1 06-28-2015 10:09 AM
A/c Blows warm muddingirl81 Cooling, Heating, Ventilation & A/C 3 09-03-2013 06:30 PM
Adding freon to 98 Expedition Chris McKelvey Expedition & Navigator 3 07-20-2012 03:37 PM
92 econoline ac refill 82ford302 1968-2013 Full Size Vans 8 05-02-2010 07:46 PM
A/C coldness? Aggie05 Bronco II 12 07-22-2005 09:44 AM
Tags
1993, 1997, 77, 98, capacities, capacity, cherokee, f150, ford, freon, grand, jeep, nova, r134, refrigerant
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
