scan II gauge - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
scan II gauge
Old 10-18-2011, 01:08 PM
VONxRUBENxLA's Avatar
VONxRUBENxLA VONxRUBENxLA is offline
VONxRUBENxLA is gaining momentum as a positive member of FTE.
scan II gauge
after seeing the ad many many times i decided to click on the link and look into them better nice and neat.
so how accurate are these and whos using them? also do they always have to be plugged in?
Old 10-18-2011, 01:28 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
It's as accurate as the sensors the PCM reads. You can leave it plugged in all the time if you want. It powers up and down on it's own. You can unplug it if you want. Won't hurt anything but is not needed unless you have to access the OBD port for some other reason (i.e. scanner).
Old 10-18-2011, 01:30 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
They're pretty accurate. It's the same info your PCM is reading from your sensors. One benefit is that it gives you a better idea what your trans temp and engine temp is as a quantitative value instead of the dummy gauge on the dash.
Here is a pic of mine with trans temp (TFT), engine temp (FwT), volts, and RPM. You can display 4 gauges at a time. It plugs into your OBDII port constantly. It can also read CEL codes. Just disconnect it when going for your smog check.
Old 10-18-2011, 01:45 PM
Nice thanks fellas.
my over head lie-o-meter is broken so i should invest in one of these instead of getting that fixed??
Old 10-18-2011, 01:51 PM
cpickner's Avatar
cpickner cpickner is offline
cpickner is gaining momentum as a positive member of FTE.
I love mine. I leave it plugged in all the time. it shuts itself after 12 seconds of no input from the computer. I have mine set up almost identical to jh818, except that my water temp is on top and trans temp is on the bottom. I really like it.
Old 10-18-2011, 01:52 PM
jh818's Avatar
It won't replace your PCM. Your PCM takes those data and then does what it needs to do to make your truck run properly. This just displays info for you.
Old 10-18-2011, 02:02 PM
Quote:
sorry dont know why i put PCM in there thats not what i meant. lol probably was on my mind cuz of reading i have that prob when i write.
Old 10-18-2011, 02:10 PM
jh818's Avatar
The only thing it displays from your lie-o-meter, I believe, is your mpg. There is no outside temp, nor miles to empty, nor compass.
Since I tow, I use it to track trans temp.
Old 10-18-2011, 02:27 PM
jh818's Avatar
There have been threads in the Excursion forum on fixing that display. Gently pull it down and see if you find some loose or broken off chips and resolder them back on.
Old 10-18-2011, 02:33 PM
not to worried about the outside temp, compass or miles till empty but miles till empty would be nice but its not ever even close to acurate. it always used to say anywhere from 240-250 and i get 200-220
Yeah my chips are actually fried and burnt off. 2 are not even attached anymore. and its gonna cost $100 to fix.
penlum inserts pilgrimbizket 1994.5 - 1997 7.3L Power Stroke Diesel 9 01-05-2015 09:37 AM
Time-Sert failure? mwsF250 1999 to 2016 Super Duty 2 11-17-2011 08:00 PM
injector life 429 f-100 1999 - 2003 7.3L Power Stroke Diesel 26 08-15-2011 01:25 PM
How many O2 sensors on a 94 F-150 5.8? BURNSTOUGHFORD 1987 - 1996 F150 & Larger F-Series Trucks 2 09-28-2010 06:49 AM
Rotating Tires Chance_Thomas 1999 - 2003 7.3L Power Stroke Diesel 8 05-31-2006 10:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
