Cannot change the rear diff fluid on F450 axle??? - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 10-26-2011, 10:59 PM
tgreening's Avatar
tgreening tgreening is offline
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Oh btw, Honda is from Japan, and we all know how wacky those folks are!
Old 10-27-2011, 03:00 PM
ETKMS's Avatar
ETKMS ETKMS is offline
ETKMS is starting off with a positive reputation.
Quote:
Originally Posted by tgreening View Post
And please don't feel the need to go getting all excited. I never said you were wrong, if you'll reread I said your terminology may be technically valid, and it is, but that most people in this country would be confused, and I stand by that whether talking trucks OR cars. Shoot, search this site and I wager you wouldn't find more than a handful of propeller shafts in the whole place. Could be wrong though, wouldn't be the first time.
I may not be classically trained, but I've been wrenching on junk more than a day or two. Friends?
Yes, still friends.. I cannot get mad at a fellow F450 owner! If you had a little F250 or F350 then maybe! JUST KIDDING GUYS! I love all super duties...
On a serious note, I still on a search to find out when ford actually wants this rear diff fluid changed. I still am coming up empty handed everywhere i look!
Old 10-27-2011, 03:29 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Perhaps this will help?
Drain
1. Drain when the lube is at normal operating temperature
(150-200F [66-93C]). It will run freely and
minimize the time necessary to fully drain the axle,
this insures the axle is flushed.
2. Remove the bottom two carrier to housing capscrews
and allow the lube to drain into a suitable
container.
Note: Dispose of all used lubricants properly by following disposal
methods approved for mineral- or synthetic-based
oils.
3. Inspect breather for clogging or corrosion. Clean or
replace as necessary.
Fill
1. Reinstall bottom two carrier to housing capscrews –
use Loctite 270 and torque to 142–158 lbs. ft. (193-
214 N•m).
2. Remove the filler hole plug from the side of the carrier
and fill the axle with the approved lubricant until
level with the bottom of the hole.
3. If wheel ends were removed, follow instructions in
the wheel end servicing section.
Always use the filler hole as the final reference. If lube is level
with the bottom of the hole, the axle is properly filled.
Note: Lube fill capacities are basic guidelines and will vary
based on the angle the axle is installed in a particular
chassis. Torque fill plug to 40–60 lbs. ft. (54–82 N•m).
TIP: The axle can be filled through the axle housing breather
hole. Fill until lube level is even with the bottom of filler hole in
side of carrier.
In a vocational setting Dana says to change the diff fluid every 60,000 miles.
Old 10-27-2011, 03:48 PM
MisterCMK's Avatar
Avid Winter Hater
Old 10-27-2011, 04:31 PM
ETKMS's Avatar
Quote:
Originally Posted by MisterCMK View Post
Excellent information! best I have seen yet! thank you..
Few things I found interesting... From looking at the diff, if you unscrew the 2 bottom bolts it did not appear that would drain, it, but i suppose I am wrong.
Also, i cannot find anywhere the capacity of this diff so I know how much oil to get.
I also found it interesting they do not want any friction modifier or additive in there? even for the LSD?
Old 10-27-2011, 08:50 PM
MisterCMK's Avatar
Avid Winter Hater
Is it a truetrac in there like the service manual seems to indicate or is it a clutched unit?
Old 10-29-2011, 04:52 PM
ETKMS's Avatar
It appers to be a truetrac.. After looking at the service manual, it states that the diff capacity is 6.6L and says it uses 75W-140. It does not state anywhere to use any friction modifiers or anything on this diff?
Old 02-03-2012, 10:03 PM
Powerstroke2000 Powerstroke2000 is offline
Powerstroke2000 is starting off with a positive reputation.
New to the F-450, as I have a (new to me 2009), and find this an interesting topic, and many questions have now been answered.
Would be helpful to know if the friction modifier is needed though, and I'll assume that 'synthetic' of the correct viscosity is used (6.6 L)?
Also, would the 'suck out' be better than the 'pulling two bolts' way of going about this job?
I'm betting there are alot of F-450 owners out there with more than 60K on their trucks that have no idea regarding changing diff oil!
Ford told me, in their opinion I had what they believed to be 'filings' in my rear diff., larger in size than what they thought was normal. Whether this is just 'fluff' or is in fact an issue to consider, my thinking is to change the fluid, so I at least can feel confident all is good. I've heard no odd noises, and the rear diff seems to be working just fine, but this is something I'll continue to watch.
Old 02-04-2012, 02:06 AM
ETKMS's Avatar
Oh, i should have posted earlier, I did this and it was SO easy! The 2 bolts at the bottom are actually drain bolts, i had no idea the fluid would just come out of both. I jacked up each side of the axle (one at a time) and got out all fluid. I then out in Mobil 1 sytentic diff fluid. I called Dana and they said a friction modifier is not needed in this diff.
Old 08-07-2014, 06:10 PM
Quote:
Haven't changed mine yet, as I'm just doing my research on doing this, so I wanted to thank you for your input, as it's been very helpful. Will be looking for 6.6L of synthetic 75w-140 fluid here real soon. So good to hear that those bolt holes do the job!
Old 08-15-2014, 05:58 PM
Superduty450 Superduty450 is offline
Superduty450 is gaining momentum as a positive member of FTE.
Just finished changing the S110 on my 08 F450 and the drain plug is the one at the 6 O' Clock position, the owners manual says 14 pints but after draining completely without pulling axels it took 5qts to refill thru the side fill plug (it's magnetic). I used teflon pipe thread sealant on the drain plug with no leakage after 1000 mi. and 4 wks time. I also used the teflon pipe sealant on the fill plug and just snugged it good, remember that is a pipe thread. I used Schaeffer's 75-140 Synthetic Gear Oil and the Schaeffer's Tech guy said no modifier needed that there is enough in it already but if chattering is experienced then add the Ford Modifier. I did figure 8s in the parking lot both left and right smooth as can be.
Old 08-15-2014, 06:10 PM
Mud Doc's Avatar
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
I said earlier there was no way to drain--around 140k miles, I was under the truck in the service bay while getting the fuel filters changed, and--guess what!--there in big letters on the lower housing are the letters DRAIN next to the bottom bolt. DUH!!
So it will be a lot easier next time.
I first had the chatter/shudder on takeoff early on--Ford said change diff fluid and add extra FM--did that and shudder was gone. I no longer have the use of the LS, guess clutches are worn out. Now at 181k and it is doing fine otherwise.
Joe
  #28
Old 11-13-2015, 08:52 AM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
bump. doing a search for drain and refill for a 2010 f-450 DRW. no obvious drain or fill plugs. will check again tonight to see if the case bolts are in fact drain bolts.
  #29
Old 11-15-2015, 07:29 AM
Mud Doc's Avatar
Guarantee you there is a drain bolt--or two.
  #30
Old 11-22-2015, 12:18 PM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Bottom bolts in the pumpkin are the drain bolts.
Factory service manual pdf? Rij1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 03-05-2017 11:24 PM
Aerostar rear bushing overhaul RojoStar Aerostar 7 06-23-2016 01:09 AM
66k Mile Service- 2012 Ecoboost Platinum dziskovs 2009 - 2014 F150 5 04-28-2016 08:11 PM
1968 F100 Dana 60.3 Questions BuzzKing 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-10-2016 04:51 AM
Some PDF Help :) smokersteve 6.0L Power Stroke Diesel 15 02-21-2011 10:05 PM
Tags
1999, 2008, 450, 64l, change, dana, diff, differential, f450, fluid, ford, oil, rear, replacement, s110
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
