1972 f250 4x4 disc brake conversion HELP will this axle work? - Ford Truck Enthusiasts Forums
Old 10-18-2011, 02:09 AM
ralphatlarge ralphatlarge is offline
ralphatlarge is starting off with a positive reputation.
i have a 1972? f250 frame that i want to covert to disc brakes it has a closed knuckle dana 44 which from what i have read cant be converted? cheaply
so i have the chance to buy a 1979 bronco d44 with disk brakes with welded spider gears i dont like the welded gears i think its half a$$ed but its cheap i know its the right year but i dont know if the bronco axle is the same width does anybody know if this axle will work Thanks!
disk brake conversion for the 8.8 rear axle shore 1978 - 1996 Big Bronco 2 10-20-2013 02:01 AM
79 DANA 44 front disc brake axle? crazed87bronco 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-01-2011 12:11 PM
Disc brake swap captbo 1966 - 1977 Early Broncos 13 01-25-2011 04:20 PM
4x4 axle combos? CowboyFromHell 1973 - 1979 F-100 & Larger F-Series Trucks 23 02-25-2009 09:37 AM
Are these weld-on C's? 460 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-14-2007 11:56 AM
Tags
1972, 44, 4x4, 72, 73, axle, axles, brake, brakes, chassis, complete, conversion, dana, disc, disk, f250, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
