F 800 Brake System - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F 800 Brake System
Old 10-17-2011, 10:25 PM
racenitro racenitro is offline
racenitro is new and has a neutral reputation at this point.
F 800 Brake System
I have a 1989 F 800 Diesel Manual Tans Disc Brakes on front Not sure what the brake system is but there is a motor that runs when the ignition is turned on. THen the parking **** is pulled, it puses the brake pedal out...
Where can I find information ont his system ..not sure it is functioning properly. When empty seems to work great but when loaded have trouble stopping sometimes.
Love the dump truck as it gets excellent mileage and has tons of power...
Old 10-18-2011, 07:56 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Does it have ABS? If so, that motor that runs is usually the ABS system going through it's self-checks.
As for braking ability, maybe check the back brakes and make sure they are working.
But in the meantime, we can wait for someone with some real experience to come by
Old 10-22-2011, 01:34 AM
rummur s.c.'s Avatar
rummur s.c. rummur s.c. is offline
rummur s.c. is gaining momentum as a positive member of FTE.
Youve got the girling.
Good stuff.
The electric motor should turn off once the engine is running. The pulsing is usually the bypass pressure building then relieving.. Its normal as the system gets older it is more and more noticeable. I tried and tried to get mine to stop doing it and I ended up just letting it be.
Old 10-22-2011, 01:41 AM
As far as braking power you should check that your rear brakes are adjusted.
Jack the tires up off the ground and adjust them out until the tires is locked then back it off until you can just barely hear the shoe rubbing on the drum.
And obviously check the fluids. Brake fluid and hydraulic fluid. Its also possible that the pump is going out? If you get the right guy in the service dept at ford he may tell you what the pumps pressure should be. You can get a gauge on there to check to see if youre in spec. Some of the pumps have a filter in them that may have gotten plugged with gunk.. If there is a bolt head on the top of the reservoir you can pull the reservoir apart and clean the screen. If there is one.
Old 10-25-2011, 03:28 AM
Thanks for the replys.
Will check the adjustment and the pressure/filter.
'97 F800 has brake electric motor and brake light flashing? lostinfords Large Truck 2 05-20-2016 08:42 PM
F800 Fleet , Need Help outboard225 Large Truck 2 06-10-2014 02:01 PM
97 F800 BRAKE PROBLEMS DPASCUZZI Large Truck 3 10-25-2012 09:51 AM
F-800 emergency brake F-JUNK Large Truck 7 05-03-2011 02:13 PM
ford c800 brake system mikem55 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-13-2008 05:49 PM
Tags
1999, 800, adjustment, brake, dump, f800, fluid, ford, forums, gvwr, higher, make, reservoir, series, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
