time for a alternator
well get in the truck this morning and started to work. got about 15 to 20 minutes down the road and the batt light came on. looked at my SCT TSX and it was showing 11.3 volts. o sh** turn around and get back to the house. i turned everthing off that i could, radio heated seats high beams fog lights. thien i was shoing about 11.7 volts. well that tells me my alternator is gone.
my question is, for you that have replaced yours what did you go with. where, brand, price and also amps too?
i have the single system on a 06 f350 lariat.
from what i have looked at on line. looks like its going to be about $200 for a 110 amp remain unit.
thanks in advance
thanks in advance
Go with a DC Power unit Lots of guys run them here
I got the 190a a few months back and so far so good
IIRC it was 370.00 or so with the wire upgrade
And this alternator is built very well
also has smaller pulley to give you the power you need at Idel and slower speeds
check it out
Ford Truck Enthusiasts Forums - BLADE35's Album: DC Power Alternator & Wire Upgrade
check it out
Here's 2 options for 140 amp alternators. Advance has a 15% off and Autozone has a 20% code you can use.
Gold Duralast/Alternator (DLG3668-8-11) | AutoZone.com
ToughOne Alternator - New - 140 Amps 92570: You
I recommend the 140 6G or 130 3G with adapter.
Josh
There is also a 230 amp Leece/Neville or Prestolite that is plug and play with 6.0's. I agree with others, even the 140 amp are not really sufficient amd something over 185 amps is better. To the OP, I realize that getting one of these DC power or Prestolites is not as feasible when ordering with a dead alternator, but if Hubert is a way to swing it, it would be a better option in the long run. You may be able to go to am international dealer and pick up a prestolite of the shelf with their warranty through international. That's what I did.
