I'm getting ready to put my turbo back on. The Ford 6.0 Turbo Install says to use hi-temp NICKEL anti-seize. I have Loctite Silver Grade anti-seize but don't know if its ok to use. I called Advanced Auto & he said what I need to use is some kind of ARP Molley something. I don't know what to do since the Ford manual says different. Please advise. Thank you.
If I remember correct, the recommended min is 1800 degrees. I found some Never Seez nickel rated at 2400 degrees. That is if you're referring to the turbo unison ring.
