Starter fails to spin
1989 F150 6 cyl. 5 speed
Turning the key to the start position does not activate the starter motor. Running a jumper cable from the battery to the starter engages the starter (and will start and run if the ignition is switched on).
It acts as it would if I did not push the clutch in when trying to start it. Which might be a good place to start.
Can someone tell me how to locate and service (as well as the name of) that starter enabling device associated with stepping on the clutch?
I have a Chilton's on this truck but was unable to find any reference to it
Thanks,
Randy
Thanks,
Randy
Kapusta
05-26-2014 09:44 PM
6.9 BLUES
03-25-2014 11:08 PM
