Starting Using Ether - Ford Truck Enthusiasts Forums
Old 10-17-2011, 05:45 PM
kneisl99 kneisl99 is offline
kneisl99 is starting off with a positive reputation.
What is the starting proceedure for starting this diesel engine using ether? I know you are not supposed to but of course it is done.
I ask because my engine starts after 10-15 seconds of cranking from cold. Maybe 2 sessions of 10-15 seconds of cranking sometimes.
Anyways its possible due to its 191,000 miles and 22 years of age the pump and injectors are crudded up.
If they are and it starts right up using ether that would tend to confirm that theory.
So if you use ether to start your tell me how you do it! (please)
Thanks!
Old 10-17-2011, 06:00 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
If you want to use ether, you need to disable the glow plugs for starters.
If the pump and injectors are original, you should replace them, they're due for it. Check the glow plugs, there are two sticky's at the top of this forum discussing the two different styles (6.9/early and 7.3/late)
Old 10-17-2011, 06:15 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Disabling glow plugs is a good idea, even though i've never bothered.
And I used Ether lots of times in my 7.3
Turn your key on, wait for the Wait To Start Light to go out, then once it's out, wait untill the clicking you should hear stops, then have someone crank the engine over, let it cranking at least 5 seconds, then give it a lil bitty shot of Ether at the end of the cold air intake tube. (DO NOT SPRAY DIRECTLY IN INTAKE) It "should" start right up as mine did. If it doesn't. Try a second time, if it still doesn't....find another ride and leave it be, or fix it right. Full tune up, and glow plugs!
Old 10-17-2011, 06:29 PM
damac damac is offline
damac is starting off with a positive reputation.
Just curious if you are doing this because your glowplugs are out and you don't want to replace them or if they are and its not starting?
When I first brought my truck home I had some issues like this where depending on how the truck was parked or how happy it was that day it would take more than one starter cycle. Lots of chugging and hinting that it wanted to catch though?
What I had found though is that even though I didn't have leaks on the ground after I replaced the return line kit, is that fuel was going back to the tank. Once I installed some clear hose in the engine bay I could see I was having to reprime the lines at every cold start when the truck had sat overnight.
Got a carrier electric fuel pump and I let it run for 10 seconds before starting and now the truck acts way different. I have the glowplugs on a manual switch and feel pretty confident I can start it up on the first try within 5 seconds of hitting the starter. I count to ten on the glowplug switch.
It was amazing how much that pump helped with the truck
Old 10-17-2011, 07:18 PM
ford 6.9 ford 6.9 is offline
ford 6.9 is starting off with a positive reputation.
i use ether evertime i start my truck if it has sat overnight or for 5 or 6 hours. Just one lil squirt is all it takes i let it for a few seconds unless it really cold out some times it takes a lil more if it is below freezing.
Old 10-18-2011, 12:12 AM
eatont9999's Avatar
eatont9999 eatont9999 is offline
eatont9999 is starting off with a positive reputation.
My glow plugs and return lines are in good order. I hold the throttle down 1/3 - 1/2 the way and crank after the WTS light goes off. It always fires off within the first 5 seconds even if it has sat for the night or even a day. After she warms up, she fires off as soon as I turn the key.
You should investigate your injection, GP and return systems.
Old 10-18-2011, 12:21 AM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
Quote:
OUCH! I would replace the glowplugs there guy, if you like I can sell you some Motorcraft GP's. They are cheap here in Billings...
Old 10-18-2011, 05:11 AM
Hmmm interesting. I believe the glow plugs are working properly. The return lines all appear to be good and tight. The engine has no stench of raw diesel and there are no drips with the engine running on the ground. I have had a Mercedes four cylinder diesel so i know a little. As to the manaul glow plug switch Ive seen the disgram. But where is the relay? I have one near the right battery that looks like it but the wires and terminal locations are different.
There is no cold air intake, just an aircleaner.
What exacly constitues a diesel tuneup? The aircleaner element is a little beat up but looks serviceable. I have not had the fuel filter off but plan to remove it soon, fill it with Diesel Kleen and start the engine and leave it sit a week.
Where would I put an electric fuel pump? Whats a good one to get?
That is using your head with the clear return fuel lines. Should be standard equipment!
Old 10-18-2011, 10:17 AM
Rollin.IH.Coal Rollin.IH.Coal is offline
Rollin.IH.Coal is starting off with a positive reputation.
i need glowplugs! and my return lines arnt leaking but the effing caps are! i have to popstart her now to save the starter! Im trying to get an elegtric fuel pump! send links pleaseeee
Old 10-18-2011, 10:45 AM
Country_boy_2007's Avatar
Country_boy_2007 Country_boy_2007 is offline
Country_boy_2007 is gaining momentum as a positive member of FTE.
the gp relay will be on the top of the intake behind and under the air cleaner. a good diesel service is done about every 100k. that would be new rebuilding the ip, new injectors and return lines and caps. as for the electric fuel pump do a serch on here, theres several people that run one
Old 10-18-2011, 04:35 PM
Hmm got a can of ether today. Just sprayed it a half second into the open end of the air cleaner. Instant start.
Could be the solution for this tried old truck with a tired old man for an owner!
When you test the GPS with a 12v light you remove the wire and put the point of the tester on the shinny pin like thing that was under the connection. Right?
The light wont light on the shinny pin but it will on the bottom of the GP.
Its the only GP I could get to without getting a months worth of physical therapy.
I think the ether should be called Glow Plugs In A Can.
Old 10-18-2011, 04:48 PM
SnuffthePunkz's Avatar
SnuffthePunkz SnuffthePunkz is offline
SnuffthePunkz is starting off with a positive reputation.
**** i feel lucky with my ole girl, never had to touch ether, even at -30 C... 3 cycles of glow plugs, and she puttered right up. Tossed me around the cab good for like 30 seconds mind you.
Old 10-19-2011, 12:44 AM
redmondjp's Avatar
redmondjp redmondjp is offline
redmondjp is gaining momentum as a positive member of FTE.redmondjp is gaining momentum as a positive member of FTE.
You may have an air intrusion problem in your fuel system somewhere. In most cases, you won't see any leaking fuel either, as the leaks can be so small that they let air in but not fuel out (fuel molecules bigger than air molecules).
You can test for this by letting the truck sit for longer and longer periods of time between starts - if the amount of cranking time is directly proportional to the amount of time since it has last been started, it's almost always an air leak that is letting the fuel drain back into the tank.
As others have stated, it's time for your diesel tuneup! At a minimum, new injectors and a return line kit with all new o-rings and injector hats. Your injector nozzles wear out and you don't get as good of atomization of the fuel which makes it harder to ignite, especially with a cold engine.
A fresh injector pump comes next . . .
Old 10-19-2011, 05:21 AM
Hmmm that might be more than what I paid for the truck in parts alone Im thinking.
Plus I am too messed up to reach over the engine to replace those things.
I DID find a bad glow plug and hope to change that soon.
95 f350 won't start Alduncan19 1994.5 - 1997 7.3L Power Stroke Diesel 12 05-15-2016 07:38 PM
Cold start issue Pheadrus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 01-03-2014 06:01 PM
Weird starting issues. 650 1987 - 1996 F150 & Larger F-Series Trucks 3 03-07-2013 10:21 PM
New to powerstroke need help, no start. black95cobra 1999 - 2003 7.3L Power Stroke Diesel 9 11-13-2012 07:40 PM
Using ether in 7.3 IDI NOLAnewshound Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-10-2011 11:03 PM
Tags
1990, apply, cycles, dies, diesel, engine, ether, f250, post, pre, reprimed, start, truck, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
