I replace my Thermostat in my 86 F-250 6.9 Diesel and it's not functioning right... - Ford Truck Enthusiasts Forums
Old 10-17-2011, 05:44 PM
giantslayer giantslayer is offline
giantslayer is starting off with a positive reputation.
About 3 weeks ago I replaced the thermostat in my 86 f-250 that has the 6.9 idi diesel w/a banks turbo and the temperure gauge seems to be running in the middle between the r and the a of normal.Is that normal? Also I replaced the lower radiator hose and when the truck has run for a while I've noticed the upper radiator hose will be hot but the lower radiator hose will be cool.Is that normal? I don't belive it is. Also I replaced the themostat w/an aftermarket one from NAPA and it had a rubber ring arond the edge which I took off so the thermostat could seat properly. Was I wrong to take that off. Also this past Saturday night I went to the store (4.5 miles) and got fuel than went inside and left the truck running and when I got back in I noticed the temp gauge was towards the high mark (L of normal). Could that be due to either a bad thermostat or air in the system? As I drove back home it did drop to the middle. AlsoHow big a job is it to replace the fan clutch and could a bad fan clutch hurt my mpg? One lat question: How do I purge the cooling system of air? I know there is air in the system. Thanks
Old 10-17-2011, 06:02 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
im going to leave most of your questions for others (search too would have helped you before flush/replacing t-stat though fyi.)
hot coolant in (upper hose) - radiator does its job (radiates the heat away from the coolant) - cool coolant out/back into block (lower hose.)
so having a much cooler lower hose than the top hose is normal.
Old 10-17-2011, 06:05 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
For starters, these engines don't like aftermarket thermostats. Some people have reported success with them, most people have problems.. You should have used a the motorcraft thermostat thats specced for these trucks.
For the radiator hose question, yes thats normal. The hot water goes into the top of the radiator, and cold water comes out the bottom. The radiators on these trucks work really well. Also, since your thermostat isn't working right, its not dumping as much hot into the radiator.
I believe there is a ball in the thermostat neck that works as a checkvalve, and that will bleed the system for you. But I haven't had one apart so I can't tell you specifics, do a search or wait for other replies.
Old 10-17-2011, 06:42 PM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
The lower hose should be a little cooler, but not cold.
X2 on not using aftermarket thermostats, do a search on here and you will find they did not work most of the time.
Changing the fan clutch is not a hard job at all, and if it is locked up it will cause lower gas mileage.
What is going on that makes you think you have air in the system.
Old 10-17-2011, 08:19 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Old 10-17-2011, 08:42 PM
josh'sdeisel josh'sdeisel is offline
josh'sdeisel is starting off with a positive reputation.
if you live on dirt roads take and power wash the **** out of your radiator because that will condridict on your readings did you put a high temp rtb paste on your thermostat? also if you have air in your ac system that could also contridict it also i think but take and get a vaccume pulled on ;your system and new freeon put in it. maybe flush out your raidiator. drain the over flow and buy the stuff at walmart and run it through your raidiator and follow the directions on the bottle. after that take and put all new fluids and antifreez in it.... heck ya it rainig now on the big red yea gona get out of the drout thank you god you are a great one
Old 10-17-2011, 11:32 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
Well...I hate to 'RAIN' on your parade, but its been raining for 4 days straight up here in MT....
Old 10-18-2011, 06:23 AM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
Quote:
send some rain down my way , AZ , choking on dust ! been a couple of years since a good rain and the garbage is piling up , cant burn it till we get some good rain storms or it will set off a wild fire !
Old 10-18-2011, 02:38 PM
well i can only do my best to try and send it over thata way but no promises
Old 10-18-2011, 05:58 PM
typefour's Avatar
typefour typefour is offline
typefour is starting off with a positive reputation.
These engines dont trap air in the cooling system like some foreign POS. Likely the napa stat isnt happy. And if the check ball in the neck is missing it doesnt hurt anything. If stuck it can take longer to bleed the back of the stat.
Old 10-18-2011, 06:59 PM
Thanks,
Should've bought a Ford O.E stat.
Cooling Issue... KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 61 06-02-2016 09:33 AM
95 5.8 cooling system questions ZombieSlayer 1978 - 1996 Big Bronco 22 06-03-2015 01:15 AM
Replaced cooling system and still overheating... bburrito Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 24 09-26-2013 02:31 PM
86 F-250 4x4 w/6.9 diesel w/banks turbo mpg. giantslayer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 11-07-2011 09:54 PM
351W Overheating Issue Rusty_S Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 15 07-25-2009 07:34 PM
Tags
150, 1986, 1989, 1993, 250, 69, 9, change, diesel, f250, ford, hose, radiator, removal, replace, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
