3 speed column shifter linkage part #s ? - Ford Truck Enthusiasts Forums
Old 10-17-2011, 11:24 AM
Tobys351.9's Avatar
Tobys351.9 Tobys351.9 is offline
Tobys351.9 is starting off with a positive reputation.
I haven't had much screen time lately and I can't seem to find anything
on the search for my '66 3 on the tree shifter linkage that needs to be
replaced because after doing the bushings it needed a little tweaking and probably has not been adjusted since it was new. Currently in two pieces.
That's the long story, short is that I now want to replace both linkages with
the newest bestest ones I can find.
Any info is appreciated. Thanks.
Old 10-17-2011, 03:16 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
by linkages, are you referring from the shift rods from the column to the trans or ???
How are your front cab mounts ?? If those are weak or wasted the cab will list forward and throw the geometry of the shift linkage out of kilter badly.
Also if the column itself has bad/worn bearings causing slop would cause problems as well.
- cs65
Old 10-17-2011, 10:29 PM
Tobys351.9's Avatar
Linkage
Rebuilt the column, has newer cab mounts.
The linkage rod didn't like getting twisted.
Where it adjusts, near the transmission, well, where it used to adjust.
I have a fair amount of round stock, might make a custom rod tomorrow.
Old 10-17-2011, 10:38 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Tobys351.9 View Post
I haven't had much screen time lately and I can't seem to find anything on the search for my '66 3 on the tree shifter linkage that needs to be replaced, because after doing the bushings it needed a little tweaking and probably has not been adjusted since it was new. Currently in two pieces.
That's the long story, short is that I now want to replace both linkages with the newest bestest ones I can find.
For shift rods, you are limited to 1965/66 F100/250 2WD only w/a 3 speed Ford type 3.03 3 speed manual all syncro trans.
Different: 1965/66 F100/250 4WD / 1965/66 F100 with 3 speed O/D / 1965/66 F250 w/the optional HD T-87 3 speed / 1965/66 F350 / 1967 and later with any 3 speed.
Old 10-17-2011, 10:50 PM
Tobys351.9's Avatar
It's a 2 wheel drive synchromesh
Thanks ND, are they easy to come by? I haven't compared the two, are they they both the same size?
Have the day off tomorrow, might take a shot at customizing one.
Old 10-17-2011, 10:53 PM
1965/66 F100/250 2WD w/Ford type 3.03 3 Speed Manual all Syncromesh Transmission
C5TZ-7326-B .. Second/Third Shift Rod / Obsolete
16.58" long / 3/8" diameter / 5/16" -24 thread at one end.
C5TZ-7328-C .. First/Reverse Shift Rod / Obsolete
19" long / 3/8" diameter / 4.53" rise / 5/16" -24 thread at one end.
No Ford Dealer or obsolete parts vendor has either one.
Old 10-17-2011, 10:54 PM
Tobys351.9's Avatar
N D
Thanks man!
Old 08-25-2012, 12:20 PM
sandydaugherty sandydaugherty is offline
sandydaugherty is starting off with a positive reputation.
'65 F100 3 on tree (no O/D0 shift rods
Is is possible to use later model rods? My truck has some aftermarket floor shifter that has a 2 foot throw from first to second, and third hit the seat! I would like to go back to original, on the column shift.
Old 08-25-2012, 12:24 PM
Quote:
No.
Welcome to FTE
See posts 4 & 6.
Old 08-25-2012, 01:19 PM
Holy Mackerel, Numberman! Forty-two THOUSAND responses!
But thanks. Do people make their own rods now?
Old 08-25-2012, 05:29 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Yes, You can make a new rod or fix the rods you have with a new welded end.
Pattern them off the rod you have.
Garbz
Old 08-25-2012, 05:45 PM
I've typed 42,303 posts. Have had...at minimum...300,000 responses!
Old 09-06-2012, 05:04 PM
rapala3153's Avatar
rapala3153 rapala3153 is offline
rapala3153 is starting off with a positive reputation.
1978 ford f-100 3 speed on the column
I need part # D7TZ-7326-A the high gear rod for 2nd and 3rd. I was able to find D7TZ-7328-A so I won't have any problems shifting 1st and reverse. If you can help please do. the motor is 300cid 4.9L
Old 09-07-2012, 01:57 AM
Quote:
D7TZ-7326-A .. 2nd/3rd Shift Rod / 17 3/16" long / 7/16" diameter rod / Obsolete
1977/79 F100/250 300/302/351M/400 / No Ford Dealer or obsolete parts vendor has any.
What's wrong with the rods? The manual control selector levers on the column have a nylon bushing in each. The bushings crack apart/disintigrate, the shift lever binds up.
btw: This is the 1961/66 forum, you should have typed a new thread asking this question in the 1973/79 forum.
Old 04-08-2013, 02:12 PM
barbarossa barbarossa is offline
barbarossa is starting off with a positive reputation.
C5TZ-7328-C
If you are still looking for the C5TZ-7328-C, I have a new old stock one listed on eBay. The item # is 181118596908.
Thanks,
Jeremy
Shift linkage broken in column? 75BigBlock 1973 - 1979 F-100 & Larger F-Series Trucks 12 12-16-2016 07:42 PM
Need help with shifter linkages dnsenne 1961 - 1966 F-100 & Larger F-Series Trucks 20 05-26-2015 07:15 PM
transfer case shifter stuck thatlittleguy? 1987 - 1996 F150 & Larger F-Series Trucks 28 11-22-2014 02:37 PM
3-speed Shifter Linkage ratrod1923 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 06-30-2014 02:22 PM
Shift Linkage Broken at the Transaxle TheEscape Escape & Escape Hybrid 1 09-08-2011 01:31 AM
Tags
1966, 1973, 303, application, chart, column, ends, f100, ford, linkage, manual, parts, rod, sale, shifter, speed, trans, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
