66 proper horn ring center?
1961/66 F100/250's have a gear/lightning bolt emblem. I don't recall what 1967's have, but 1968/70's have a Ford oval center emblem, it's not blue.
This is the correct center for your '66,assuming its 2WD, also used on '64 and '65. the one with "Product of Ford Motor Company". http://www.ebay.com/itm/1963-FORD-TRUCK-STEERING-WHEEL-HORN-BUTTON-213-/321085255576?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4ac22c2f98&vxp=mtr Seller states " 1963" which is wrong. 61-63 used the gear and lighting bolt center.
Tripleframe says '66 250's do not have gear a lighting bolt emblems on horn buttons. I bet Tripleframe is right, he has provided accurate complete information on every post I've seen,and you are wrong, unless of course, you can prove it. Your answer is a shot gun answer, all over the place and missing the direct question.
Horn buttons had the gear/lightning emblem...it was cast into it...as it was also on the 4WD Custom Cab horn rings...only the 2WD chrome horn ring used on 64-66 trucks as well as the early Falcons that used the potmetal ring vs the painted steel used 67-71 trucks...same ring otherwise...these rings had an insert in the center that was changeable in most instances. The truck insert on all 64-66 CC 2WD horn rings said product of Ford Motor Company around the outer edge with the Ford oval in the center with black background and silver or white logo/lettering.
- cs65
- cs65
"Dolichovespula maculata" : Bald-faced hornet, actually not a true hornet but a wasp without the yellow markings. Not terribly aggressive but will deliver a nasty sting if he gets the chance. I think he went in the valve tube to nap for the winter when you weren't looking.
I think the gear/lightning bolt centre is removable but I don't want to check - the Dennis Carpenter "nylon" retainer is as tough as candle wax.
Eric
Eric
Eric
Eric
I'm glad you mentioned the nylon retainer, I bought a repro and it broke the first time I applied the horn. They evidently need to rework the formulation of that plastic. Does anybody know a good place to find one that will last?
