Engine Removal ?
Old 10-17-2011, 10:15 AM
halphast's Avatar
halphast
halphast is offline
Engine Removal ?
Getting ready to pull the engine on a 05' 6.0 PSD to change the cam. Just wondering if I have to pull the cab ? or can I just pull the engine the old fashion way ?
Lifter failure, roller bearing through low pressure oil pump. Ran great the first 200,000 miles.
Thanks
Another halphast repair
Old 10-17-2011, 10:37 AM
KIDkiser's Avatar
KIDkiser
KIDkiser is offline
Thanks
no need to pull the cab.just the radiator,intercooler and grill.
Old 10-17-2011, 04:03 PM
smokersteve's Avatar
smokersteve
smokersteve is offline
http://www.fordtechservice.dealercon...wSuperduty.pdf
I/we woul love to see some pictures!
How much does the oem cam go for? and the LPOP?
Old 10-17-2011, 05:12 PM
Ian123's Avatar
Ian123
Ian123 is offline
I've heard its quite a bit of work to change a cam on a 6.0, good luck and post pics!
Old 10-17-2011, 08:48 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
I pull cabs on these trucks whenever any repair calls for removal of either the cylinder heads or the engine itself. If you have access to a two-post lift, I would pull the cab without even thinking about it. The relative simplicity of it, and how much more cleanly the job will go makes it worth it. Not to mention your back will thank you for it.
Thanks
OUCH!!! I don't envy you one bit. You might want to add an oil cooler to your shopping list too. You are aware that the camshaft is literally the LAST part of the engine that comes out, RIGHT?
Old 10-17-2011, 10:10 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
out of curiosity did you do any extended oil change intervals??
what kinda oil did you run???
Old 10-17-2011, 11:14 PM
halphast's Avatar
halphast
halphast is offline
I work in a shop in Denver, but no two post lift.
I do know the cam comes out last. I have access to International web site but not Ford.
I been trusting you guys for much of my knowledge.
Gotta pull the crank and I know not to take off the flange.
I will add the cooler, I think i like the one from bulletproof,
I don't know much about the maintenance. Only had it two weeks before the trouble started. (cranks no start)
Ford dealer in Fort Collins showed me a Oasis report. Most service was done between 3500 miles to 4500. All ford stuff. Still running premium gold Anti freeze. EGR cooler only part replaced in 213,000 miles.
Oh yeah the OEM cam is $637.00 Front cover (LPOP) $504.00 ARP Head studs $498.00
16 new lifters $509.00 and so on
Thanks for all the info
Hope to have it back on the road after Christmas.
Old 10-18-2011, 01:04 AM
maverick1701's Avatar
maverick1701
maverick1701 is offline
dang that sounds like quite a job...take lots o pics
Old 10-18-2011, 11:21 AM
smokersteve
arp head studs from browns deisel are $398.
Old 10-18-2011, 11:41 AM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
May as well just buy a rebuilt short block. They are like 4k but all you have to do is replace it and your done.
Old 10-18-2011, 11:58 AM
smokersteve
another option is to buy a pice of ***** 6.0 truck and rebuild part of the motor.
What are the Stock specs for the OEM cam shaft?
Old 03-08-2015, 10:37 AM
shinnyboots65's Avatar
shinnyboots65
shinnyboots65 is offline
gentlemen I have a 2002 7.3 it dropped a cylinder number 8 I replaced the injector but to no avail im thinking about removing the engine and getting it rebuilt I've worked on gas engines all my life but I know nothing about these fly by wire diesel engines how difficult is this task going to be the engine has 265k mileage and a lot of idle time beings that i'm in construction
Old 03-08-2015, 11:42 AM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
Try the 7.3 forum and start your own thread. Use heavy duty equipment these engines are heavy and I do not trust the light duty fold up jobs on the lift or tranny jack. Use a heavy duty engine stand also.
Old 03-09-2015, 11:51 AM
Runs-wifey's Avatar
Runs-wifey
Runs-wifey is offline
Old 03-09-2015, 12:25 PM
Super Duty Service's Avatar
Super Duty Service
Super Duty Service is offline
Former Vendor
Lifters can be had for about $300. Gotta buy the kit with 4 lifters n the guide.
You need 4 of these
OneCylinder
04-26-2020 07:48 PM
Jarryd
04-21-2015 03:14 PM
mikeeep
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
07-18-2002 01:17 PM
bikerwolfie
05-21-2002 05:51 PM
inliner
03-01-2002 11:27 AM
Quick Reply: Engine Removal ?
