Engine Removal ? - Ford Truck Enthusiasts Forums
Engine Removal ?
Old 10-17-2011, 10:15 AM
halphast's Avatar
halphast halphast is offline
halphast is starting off with a positive reputation.
Engine Removal ?
Getting ready to pull the engine on a 05' 6.0 PSD to change the cam. Just wondering if I have to pull the cab ? or can I just pull the engine the old fashion way ?
Lifter failure, roller bearing through low pressure oil pump. Ran great the first 200,000 miles.
Thanks
Another halphast repair
Old 10-17-2011, 10:37 AM
KIDkiser KIDkiser is online now
KIDkiser is starting off with a positive reputation.
Thanks
no need to pull the cab.just the radiator,intercooler and grill.
Old 10-17-2011, 04:03 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
http://www.fordtechservice.dealercon...wSuperduty.pdf
I/we woul love to see some pictures!
How much does the oem cam go for? and the LPOP?
Old 10-17-2011, 05:12 PM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
I've heard its quite a bit of work to change a cam on a 6.0, good luck and post pics!
Old 10-17-2011, 08:48 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
I pull cabs on these trucks whenever any repair calls for removal of either the cylinder heads or the engine itself. If you have access to a two-post lift, I would pull the cab without even thinking about it. The relative simplicity of it, and how much more cleanly the job will go makes it worth it. Not to mention your back will thank you for it.
Thanks
OUCH!!! I don't envy you one bit. You might want to add an oil cooler to your shopping list too. You are aware that the camshaft is literally the LAST part of the engine that comes out, RIGHT?
Old 10-17-2011, 10:10 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
out of curiosity did you do any extended oil change intervals??
what kinda oil did you run???
Old 10-17-2011, 11:14 PM
halphast's Avatar
I work in a shop in Denver, but no two post lift.
I do know the cam comes out last. I have access to International web site but not Ford.
I been trusting you guys for much of my knowledge.
Gotta pull the crank and I know not to take off the flange.
I will add the cooler, I think i like the one from bulletproof,
I don't know much about the maintenance. Only had it two weeks before the trouble started. (cranks no start)
Ford dealer in Fort Collins showed me a Oasis report. Most service was done between 3500 miles to 4500. All ford stuff. Still running premium gold Anti freeze. EGR cooler only part replaced in 213,000 miles.
Oh yeah the OEM cam is $637.00 Front cover (LPOP) $504.00 ARP Head studs $498.00
16 new lifters $509.00 and so on
Thanks for all the info
Hope to have it back on the road after Christmas.
Old 10-18-2011, 01:04 AM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 has a good reputation on FTE.maverick1701 has a good reputation on FTE.
dang that sounds like quite a job...take lots o pics
Old 10-18-2011, 11:21 AM
arp head studs from browns deisel are $398.
Old 10-18-2011, 11:41 AM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
May as well just buy a rebuilt short block. They are like 4k but all you have to do is replace it and your done.
Old 10-18-2011, 11:58 AM
another option is to buy a pice of ***** 6.0 truck and rebuild part of the motor.
What are the Stock specs for the OEM cam shaft?
Old 03-08-2015, 10:37 AM
shinnyboots65 shinnyboots65 is offline
shinnyboots65 is starting off with a positive reputation.
gentlemen I have a 2002 7.3 it dropped a cylinder number 8 I replaced the injector but to no avail im thinking about removing the engine and getting it rebuilt I've worked on gas engines all my life but I know nothing about these fly by wire diesel engines how difficult is this task going to be the engine has 265k mileage and a lot of idle time beings that i'm in construction
Old 03-08-2015, 11:42 AM
dannyboy950 dannyboy950 is offline
dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.
Quote:
Try the 7.3 forum and start your own thread. Use heavy duty equipment these engines are heavy and I do not trust the light duty fold up jobs on the lift or tranny jack. Use a heavy duty engine stand also.
Old 03-09-2015, 11:51 AM
Runs-wifey's Avatar
Runs-wifey Runs-wifey is offline
Runs-wifey has a good reputation on FTE.Runs-wifey has a good reputation on FTE.
Old 03-09-2015, 12:25 PM
Super Duty Service Super Duty Service is offline
Former Vendor
Super Duty Service has a great reputation on FTE.Super Duty Service has a great reputation on FTE.Super Duty Service has a great reputation on FTE.Super Duty Service has a great reputation on FTE.
Lifters can be had for about $300. Gotta buy the kit with 4 lifters n the guide.
You need 4 of these
No Crank 08-5.4 new battery,starter Mrvegasmax 2004 - 2008 F150 5 01-25-2016 07:46 PM
Question on heater core lines Carmax 1961 - 1966 F-100 & Larger F-Series Trucks 2 08-05-2015 05:46 PM
Dana 50 oil capacity ??? IS THIS A MISPRINT!! harley4jcs Excursion - King of SUVs 6 06-18-2015 06:25 PM
Stamped Aluminum Heads? JordanL91 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 05-27-2015 02:14 PM
!!!Help!!!-Middle of New Injector Job-Not going well Haggs21 1999 - 2003 7.3L Power Stroke Diesel 26 03-16-2014 11:57 AM
Tags
02, 03, 460, 60, 73, 75, engine, f100, f250, f350, ford, ranchero, removal, remove, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
