99 V10 F450 needs a motor
Last week I purchased a 450 4x4 auto that needs the motor replaced. I've been on car-part.com and there aren't many 99s available that have decent mileage. However, I've been led to believe that the V10s built in 2000-04 will also work. Is that true? If so what's the deal with the EGR? Many of the listings say "Missing EGR" or "Check EGR", is that a critical component or is it a part that my mechanic can buy at Napa?
Also, is there a better source for engines outside of car-part? I've been using that site for quite a while with great success but I'm always on the lookout for other options. Thanks guys
A lot of the 00'-04' SD V10 did not come with EGR. My 04' does not have EGR. I would try and get ahold of a 2003 or 2004 V10 because of the increased spark plug thread count and it is a PI engine with more power vs your 99'. The PI engines came out in 2000.
The EGR is not really a big deal if you don't live in California or places that adopted California emissions requirements. You can delete the EGR system completely and turn the EGR functions off with a tuner with a custom tune or you can just transfer your EGR system and drivers side exhaust manifold with the EGR tube over to the new engine. I will bet money if you try and remove the EGR tube from the exhaust manifold it will break off or have to be cut off due to corrosion.
My Ex with the V10 from '02 was a CA truck all it's life and I don't believe I have an EGR on it. I've seen other V10s has a metal tube coming out of the middle of the exhaust manifold on the driver's side for the EGR, but mine doesn't have one. It looks like it came from Ford without it.
Its been a a long time since I was a California resident but I believe if you put a 2004 engine in a 1999 truck then you must include all the emission equipment that was on the later MY engine. If the 1999 had EGR and the 2004 did not as long as you have a 2004 MY engine you will be good to with no EGR.
Of course the OP has never said where they are from so does this really matter?
Make sure you get the intake with the new engine! The PI heads require a different intake. Most everything else is the same.
You will need to lengthen one heater core hose with a 3/4" to 5/8" (I believe...) adaptor. On the '99, one hose goes to back of intake manifold. On the PI engine, it goes to front right of intake manifold.
If you want to retain the EGR, just use your old driver's side exhaust manifold and plumbing. There should be a block off plate on the new intake manifold that just unbolts to fit in the EGR. That's what I did.
Feel free to ask any other questions! The PI is a nice upgrade and well worth the effort.
It looks like it would be easy enough to swap the manifolds. If I go that route do I need to swap out any other parts...like the intake?
Hello, I don't know about the egr stuff. But it is common for the exhaust manifold studs to rust and break off. Now with the motor out is the best time to pull the manifolds and replace the studs with stainless steel studs or bolts. That way you won't have to do it when it is installed.
The engine swap is underway and I'm at a crossroad. I can't decide whether to swap the EGR or if I should find a way to tune out its function. I'd probably be money ahead by swapping it, right?
